thermostat(s) gasket leaks - JeepForum.com
post #1 of 2 Old 05-08-2015, 11:53 PM Thread Starter
Richie09
The smaller thermostat which seats right up against the head was bought as OEM. After three years the gasket started to leak, you can see small amount of coolant fluid below it and on top of the tranny.
This is not an installation problem, the round white gasket has become weak and "crumbling", it also compressed somewhat ( new thickness; .200; the one removed; .015)
It is not a nasty job to replace it but maybe you will prevent an overheat.
hope this helps
P.S. would be same 2.0 L gas as my Caliber, 2.4 L maybe same too but not sure.
Richie09 is offline
post #2 of 2 Old 05-15-2015, 01:35 AM
Hondatrix
To what spec did you torque the bolts?
Hondatrix is offline
