Temp. Gauge - JeepForum.com
post #1 of 10 Old 01-20-2008, 02:45 PM Thread Starter
Chriztofor
2007 MK Compass
Temp. Gauge
I just noticed that when my car is warm my temp. gauge needle is at one mark passed the cold position. When you engine is warm is yours located in the middle of the gauge?
Chriztofor is offline
post #2 of 10 Old 01-20-2008, 04:28 PM
Jeepster55
yea, pretty close to middle anyway. not quite straight up-and-down. do you have heat? notice any leaks? OR is it just freaking COLD outside? (Zero or less....)
Jeepster55 is offline
post #3 of 10 Old 01-20-2008, 04:41 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Mine runs in this zone. To the left side of the circle when it's winter; to the right side in the summer. The only time it's been all the way up to half way was in AZ @ 107 degrees.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #4 of 10 Old 01-20-2008, 04:59 PM
Jeepster55
thanks for the pic, Gramps. that's right where MINE runs too......you know what they say; "A picture is worth a thousand words"
post #5 of 10 Old 01-20-2008, 06:05 PM
Laloggia
2010 JK Wrangler
When its 25 degrees or colder, mine runs at about the 1/4 mark between C and middle. When its warmer, it runs just to the left of the middle. It really depends on how cold it is outside. Summer....its normal. I have heat either way. I think i would rather have it running cooler anyways.
2010 Wrangler Islander
2005 Chrysler Crossfire
2010 Honda Crosstour
2007 Honda Civic Coupe
Laloggia is offline
post #6 of 10 Old 01-20-2008, 10:05 PM Thread Starter
Chriztofor
2007 MK Compass
Thanks! It is 4 degrees here in Chicago. I have heat just wondering if something is wrong. On my other car it is dead middle no matter what the temp.. Good to know that the temp gauge fluctuating, depending on the climate, is normal on our cars. I love this board!
post #7 of 10 Old 01-21-2008, 05:01 PM
Coasty161
temp is usually around the same as the pic in post #3. every once and a while it gets up to the middle when driving slow on the logging roads.
Coasty161 is offline
post #8 of 10 Old 01-21-2008, 07:28 PM
JeepinGirlCT
JeepinGirlCT's Avatar
It was 8 degrees when I left for work this morning, and 22 when I left. It hangs around the area noted in post #3. I'll check again tomorrow morning (I do let it warm up before going to work).
JeepinGirlCT is offline
post #9 of 10 Old 01-26-2008, 02:54 AM
hvac59
hvac59's Avatar
Mine runs in about the same place also! I'm using a SCANGAUGE too, whisch reports anywhere from 177 to 186 on my commute to work. I'll keep an eye on it and post back when it changes in relation to the dash gauge. Does seem a little on the cool side. I mean my other vehicles seem to run in the 200 range!
hvac59
White 01 WJ (stock 4.7 limited)
White 08 MK Patriot (minor mods) -SOLD-
Looking for a White (ultralite?) project Jeep -FOUND-
White 09 JK "X"
hvac59 is offline
post #10 of 10 Old 01-26-2008, 04:58 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
This past week with the start of my days @ -15 it's been sitting right on the 1/4 mark. That's after being warmed up and all the way threw my 25 mile drive. It goes back to my normal as indicated in post 3 when the outside temps get up to 0 to 10 or so. I don't hardly remember any of my stuff running that cold for a long time. They've all been up around the 190 - 200 mark because that's the temp of the thermostat but my Compass seems to run fine with the variations.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
Ambient temp sensor stuck on 76 degrees. horsepower Jeep Compass & Patriot Forum 7 08-31-2010 04:02 PM
Gear shift lock-up..easy temp fix tazman900 Jeep Compass & Patriot Forum 0 07-11-2009 04:36 PM
Gauge Cluster Sgt_K Jeep Compass & Patriot Forum 4 05-29-2009 09:19 AM
A/C and external temp sensor problems and car won't accelerate gajeepchick Jeep Compass & Patriot Forum 7 09-30-2008 07:20 PM
Gas gauge off by a tick? handyman98 Jeep Compass & Patriot Forum 3 08-15-2008 11:48 PM
