Tailgate up/light - JeepForum.com
post #1 of 8 Old 08-05-2008, 09:04 PM Thread Starter
Elihawk
2008 MK Compass
Tailgate up/light
My Compass has the rear flipdown tailgate speaker. I have noticed that when you have the tailgate up, the rear dome light is on. Anyone know if their is a way to have the tailgate up and NOT have the dome light on? I don't want to run the battery down anymore that necessary....
Elihawk is offline
post #2 of 8 Old 08-05-2008, 09:50 PM
roland365
2008 MK Patriot
i can take mine out cuz its the flashlight...just got my pat so i havent thought about that...good question
roland365 is offline
post #3 of 8 Old 08-06-2008, 03:38 AM
CharBroiled
pretty sure there is there is (I thought I did it once) but I cant for the life of me remember how atm. it was more or less accidental, one day I just noticed the lights were off with the hatch open. If I can remember Ill let you know. [edit: I did remember - see below]
I also have the removable flashlight but it was in at the time. BTW the dome light stays in (and on) its just the flashlight that come out.
on my XJ when the hatch is open you just "click" (pushed up on) the rear dome and it switched the interior lights off. do that on our the MK and the flashlight just falls out
for some reason I think it had to do with the steering wheel light stalk, like setting the dash lights dimmer on its "daylight" setting or something.
EDIT: OK checked it. just rotate the dimmer control on the light stalk to the "o" (all the way back) and all interior lights go off with the hatch open.
2000 Cherokee Sport 4.0L Selec Trac - mine - for occasional wheeling
2007 Patriot 2.4L FD I 4x4 - wifes - doomed to rarely leave the street
CharBroiled is offline
post #4 of 8 Old 08-06-2008, 06:11 AM
roland365
2008 MK Patriot
thanks!....
post #5 of 8 Old 08-06-2008, 10:43 AM
parajeep
2007 MK Compass
Turn the interior/dashboard lights all the way off. It is on the left of the steering column, on the headlights/foglights/turn signal "wand."
parajeep is offline
post #6 of 8 Old 08-06-2008, 07:32 PM
howdy246
2008 MK Compass
I noticed that the other day too, I think it has to do with the position of the key in the ignition. Just turn the key o the radio comes on and no further, that should make the dome light go off after a few minutes. I only think this is right because I have had the dome light off with the tailgate up and its the only thing I can think of that may be different.
howdy246 is offline
post #7 of 8 Old 08-07-2008, 02:06 PM Thread Starter
Elihawk
2008 MK Compass
I don't believe it has to do with the ignition...the same as if you leave your driver's door open, the dome light comes on and stays on. I will try the dim function on the internal lights...thanks!
Elihawk is offline
post #8 of 8 Old 08-10-2008, 08:19 PM
howdy246
2008 MK Compass
I had the hatch opened and the radio going for about 6 hrs the other day. The light was on the whole time and it started right up with no problems.
howdy246 is offline
Airbag light Laloggia Jeep Compass & Patriot Forum 15 03-19-2017 09:00 PM
ESP/BAS light on Gramps Jeep Compass & Patriot Forum 17 02-28-2017 06:26 PM
Aftermarket light bar Tony1911 Jeep Compass & Patriot Forum 1 08-27-2009 05:54 AM
liberty light bar Havoc74 Jeep Compass & Patriot Forum 8 05-01-2009 02:45 PM
Fog Light Problem lynnk Jeep Compass & Patriot Forum 3 02-16-2007 07:39 AM
