Strange "Oil Change Required" Behavior - JeepForum.com
post #1 of 3 Old 07-01-2012, 06:33 AM Thread Starter
WingedScapula
2009 MK Compass
Hi guys,
I've done a forum search for this issue but couldn't find anyone else mention it, so I thought I'd run it by all of you.
I've seen the "oil change required" indicator before. For me, it usually comes on at around 5,000 miles (although I know it's not distance-based, but rather takes other factors into account). If I remember it right, the message stays lit for a few seconds, and the check engine light comes on. No problem.
In this case, I had driven about 300 miles on a highway, took a break for about 20 minutes, and when I started the car again, the message came up, and has been coming up ever since then. I had only driven about 1,500 miles since my last oil change.
However, it's a bit strange, which is why I wanted to run it by all of you. It seems as if the message appears after about three to five seconds of starting the car, which is longer than I remember it taking. More importantly, it disappears very quickly, either before or right around the time that the warning tone stops. The check engine light never illuminates during this whole process.
I've read over the procedure for resetting this indicator, which I'm thinking about trying. Two questions: is this a cause for concern about anything? And am I somehow mis-remembering how the usual oil change indicator worked, and this is how it's always been?
Thanks for the help!
WingedScapula is offline
post #2 of 3 Old 07-01-2012, 12:01 PM
FujativeOCR
2011 MK Patriot
If there's no check engine light associated with it I wouldn't be too concerned. If it were me, I'd do the reset procedure, and keep an eye on it for a few start cycles. I think if there's any problem it has to happen multiple starts in a row or there won't be a code and associated light. If you reset it and it comes on again then I'd assume something is up. Also. Check your oil level. Maybe somebody didnt tighten a filter and you lost some.
FujativeOCR is offline
post #3 of 3 Old 07-01-2012, 12:03 PM
FujativeOCR
2011 MK Patriot
Oh and I think there usually is a delay for the oil warning after starting the car. I think the car runs a few self diagnostics when you turn the key to on and it takes a few seconds to figure out the results.
'Oil Change Required' Message mdneve Jeep Compass & Patriot Forum 2 05-09-2012 04:50 AM
driver side front "churp/squeek" armystrong68w Jeep Compass & Patriot Forum 17 03-13-2011 07:40 PM
Mopar "Flat Molded Splash Guards" or "Deluxe Molded Splash Guards"? Beware Jeep Compass & Patriot Forum 8 05-03-2009 04:48 AM
Annoying "Oil Change" warning izzoe46 Jeep Compass & Patriot Forum 13 10-23-2008 11:16 AM
Should we remove the "No Comments" in the owners pics thread Gramps Jeep Compass & Patriot Forum 4 12-09-2007 08:29 PM
