Strange honking noise from brakes while reversing - Page 2 - JeepForum.com
post #16 of 18 Old 05-16-2007, 09:45 AM Thread Starter
Doba
Originally Posted by Gramps
Doba,
Sorry that I didn't look here earlier. I didn't expect to see this in the SM, it's very lean on any trouble shooting info!
Found this in the Service Manual:
DISC BRAKE MOAN OR HOWL WHILE BRAKING IN REVERSE
Rear disc brake caliper guide pin bolts installed in incorrect locations.
Remove lower guide pin bolt and inspect for special sleeve on tip. If sleeve is present, remove upper and lower guide pin bolts and install special sleeved bolt in upper location and standard guide pin bolt in lower location. Perform on both sides of vehicle. Replace rear brake pads.
Thanks Gramps, I'll have to print this out and take it to the service department.
Doba is offline
post #17 of 18 Old 12-19-2007, 12:15 PM
zxjockey
2007 MK Patriot
Mine just started doing this as well. I'm going to the dealer with this blurb myself. What a teeth-cracking sound!
zxjockey is offline
post #18 of 18 Old 12-19-2007, 02:49 PM
Trek620
2008 MK Patriot
Liberty's had this
My 05 Liberty had this same problem and eventually there was a TSB to fix it. Took it to the dealer, informed them I knew of the TSB and they fixed it no charge. If you search the Liberty forum you can find more info. Too bad it's carried over to your Compass. So far my Patriot has not had the problem.
Trek620 is offline
Brake squeak when reversing Trek620 Jeep Compass & Patriot Forum 15 08-03-2010 11:24 PM
Antilock brakes engage when i hit bumps/potholes eviladam Jeep Compass & Patriot Forum 3 03-04-2009 10:08 PM
jumpy brakes grey2007 Jeep Compass & Patriot Forum 3 01-03-2009 03:02 PM
A/C noise thudson331 Jeep Compass & Patriot Forum 3 04-11-2008 09:06 PM
Really Strange Part...on my Compass AmercanEagleDud Jeep Compass & Patriot Forum 10 07-06-2007 03:30 AM
