Strange honking noise from brakes while reversing - JeepForum.com
post #1 of 18 Old 05-07-2007, 11:11 AM Thread Starter
Doba
Our Compass has been doing this for a few months now. When going in REVERSE only and lightly on the brakes they make an aweful sound. We asked the dealership and they told us there was nothing they could do and that was the way it was going to be. I can't accept that answer and I'm looking for a better one. Has this happened to anyone else?
Doba is offline
post #2 of 18 Old 05-07-2007, 11:33 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I have brake drag noise only in the morning backing out of my drive way after sitting over night, no other time. I never thought much of it because I've had that on other stuff too. Seems to be less now that the weather is warming up and drying out. Totally different weather between Phoenix and Madison.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 18 Old 05-07-2007, 12:30 PM Thread Starter
Doba
It is all the time and pretty loud. Pretty embarassing driving a brand new car and it makes those types of noises.
Doba is offline
post #4 of 18 Old 05-07-2007, 02:28 PM
CoriolisSTORM
WHAT?!
CoriolisSTORM's Avatar
2010 JK Wrangler
I know the brakes adjust themselves when you reverse, my Caliber makes a sort of grinding noise when backing up.
1998 TJ Wrangler SE - Stone White, 2.5Ls of screaming lifter clacking power, AX5, 31" BFGoodrich All Terrain T/A KOs
2010 Wrangler Unlimited Sahara - Deep Water Blue, 3.8Ls of oil consuming fury, NSG-370, BFGoodrich Rugged Terrain T/A 265/70/R18s
CoriolisSTORM is offline
post #5 of 18 Old 05-11-2007, 11:24 AM
indianrefining
Originally Posted by Doba
Our Compass has been doing this for a few months now. When going in REVERSE only and lightly on the breaks they make an aweful sound. We asked the dealership and they told us there was nothing they could do and that was the way it was going to be. I can't accept that answer and I'm looking for a better one. Has this happened to anyone else?
Maybe it's that guy behind you!
indianrefining is offline
post #6 of 18 Old 05-12-2007, 07:37 AM
BuzzDog
Try SLAMMING on the brakes a few times in reverse. Might just be an automatic brake adjuster that needs to be freed up.
BuzzDog is offline
post #7 of 18 Old 05-14-2007, 11:40 AM Thread Starter
Doba
Somehow I don't think that is it.
I'll try slamming the breaks and see if that works.
Doba is offline
post #8 of 18 Old 05-14-2007, 11:53 AM
unibus
2007 MK Compass
The Compass has 4 wheel disk brakes.... There are no "adjusters" as one would have with a drum style brake system.
unibus is offline
post #9 of 18 Old 05-15-2007, 05:19 AM
BuzzDog
Doh...I knew that! However, I wonder why my rear brake drag goes away for a few weeks when I slam the brake pedal in reverse?
BuzzDog is offline
post #10 of 18 Old 05-15-2007, 06:49 AM
unibus
2007 MK Compass
If as you said.... "Doh...I knew that!" then why did you mention it in your above post.
Aside from that, if your rear brakes are dragging then there is something wrong with them that you should have the dealer attend to or fix yourself. Dragging brakes will cause excessive brake wear, lower mileage, or worse warp the rotors.
unibus is offline
post #11 of 18 Old 05-15-2007, 04:19 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Doba,
Sorry that I didn't look here earlier. I didn't expect to see this in the SM, it's very lean on any trouble shooting info!
Found this in the Service Manual:
DISC BRAKE MOAN OR HOWL WHILE BRAKING IN REVERSE
Rear disc brake caliper guide pin bolts installed in incorrect locations.
Remove lower guide pin bolt and inspect for special sleeve on tip. If sleeve is present, remove upper and lower guide pin bolts and install special sleeved bolt in upper location and standard guide pin bolt in lower location. Perform on both sides of vehicle. Replace rear brake pads.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #12 of 18 Old 05-15-2007, 09:35 PM
pillzny
My brakes also make that sound in the morning or for sitting for a couple of hours... especially after rain. I just pump the brakes a couple of times and it goes away
pillzny is offline
post #13 of 18 Old 05-15-2007, 10:08 PM
BuzzDog
I knew I have four wheel disks, but just forgot about the minor detail of not having adjusters. I may be a bit older than you, and may have a few more things on my mind than you do.
Please don't be so quick to judge...I though people were nice on this forum? Guess I may be wrong...
BuzzDog is offline
post #14 of 18 Old 05-16-2007, 04:49 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Lighten up guys! I could have said something really dumb like "make sure your brake rods aren't bent". How many remember non-hydraulic brakes?
Even though there are no adjusters on disc brakes this procedure may work. Disc brake pads get a glaze built up on them and slamming on the brakes in reverse sometimes acts like sandpaper to remove the glaze. Same result just a different reason why it works.
Something else I'll add to my "dumb" list; I was always checking the air pressure in the tires dururing the winter and pumping them up as needed. Don't forget to check them now that the temps have warmed up, I was up to 41 lbs COLD!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #15 of 18 Old 05-16-2007, 06:54 AM
unibus
2007 MK Compass
No offense intended BuzzDog... I just don't like to see misleading info ( I get enough of that from the dealership ) that might misdirect those who have minimal car knowledge.
I'll try not to jump so fast next time.
unibus is offline
Brake squeak when reversing Trek620 Jeep Compass & Patriot Forum 15 08-03-2010 11:24 PM
Antilock brakes engage when i hit bumps/potholes eviladam Jeep Compass & Patriot Forum 3 03-04-2009 10:08 PM
jumpy brakes grey2007 Jeep Compass & Patriot Forum 3 01-03-2009 03:02 PM
A/C noise thudson331 Jeep Compass & Patriot Forum 3 04-11-2008 09:06 PM
Really Strange Part...on my Compass AmercanEagleDud Jeep Compass & Patriot Forum 10 07-06-2007 03:30 AM
