Steel Wheels and Snow Tires? - JeepForum.com
post #1 of 8 Old 09-17-2006, 11:34 AM Thread Starter
ponderosa
2007 MK Compass
I like my compass overall. I'm planning on putting on some steel wheels (cheap) and good snow tires (tall and narrow) for the winter.
I've had experience with wheels and offset is inportant.
Is the Compass wheel requirements 4.5" bolt pattern?
Bore diameter? Guess the tire shop would know.
Offset? did a measurement with a tape measure. Looks about 1" positive but have to know for sure. Where could I find out?
Thinking 8" wheels X 16 with 75 or 80 series 195 or 205mm
Continental has a 195 80 15" snow tire. Maybe too small.
Crager 8 hole wheels are in the budget. Hey, I did buy a economy car!
ponderosa is offline
post #2 of 8 Old 09-17-2006, 12:23 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
ponderosa,
Kev M is looking in the same area. He started the thread under "Tire Pressure Monitoring System" elsewhere under Compass.
http://www.jeepforum.com/forum/f98/tire-pressure-monitoring-system-question-303655/
Did you get the Monitoring system on yours"? That could complicate things a little. Let us know what works.
Gramps is offline
post #3 of 8 Old 09-17-2006, 05:02 PM Thread Starter
ponderosa
2007 MK Compass
No pressure monitoring system
I did not get any options on my Limited except the smoker package. Girlfriend likes the lighter. I loved the seats and Auto Stick. It drives great on back roads.
The Tire Rack shows 100+ wheels for the compass. I'm concerned about the offset. I can take my wheel off and use a straight edge and measure from the hub mounting surface to the outer edge. Then edge to edge and do the math.
Belle Tire here in Michigan is a quality outfit. I'll see what they suggest.
post #4 of 8 Old 12-24-2006, 09:58 PM
Kozmotoo
Wheel Offset and Max O.D.
The wheel offset is somewhere between 38 and 42mm (I can't recall which wheel got what offset). The maximum tire OD is the 215/65R17 (28.0"/711mm).
Reducing the factory offset (wheel going out) while increasing the tire OD are both directionally wrong for clearing the front fender lip. You'd run the risk of body damage in the event of an extreme jounce+full turn condition. Not common, but certainly possible.
Kozmotoo is offline
post #5 of 8 Old 12-24-2006, 10:02 PM
Coasty161
so then 235/65/17 would be to wide?
Coasty161 is offline
post #6 of 8 Old 12-25-2006, 09:03 PM
Kozmotoo
Too wide?
An OEM would certainly tell you yes, but they factor in all the worst case, yet reasonable maneuvers; like 90% jounce (well into the jounce bumper), full outer turn, 80% bushing compliance, grown tire, with body and chassis build tolerance going in the worst-case direction...
Despite that kind of conservatism, I agree with their stance. I wouldn't use a wider tire. I'm not even sure that's an advantage when it comes to snow and ice traction.
Just realized this: That would be much too large in the OD also! A full inch larger OD. That, combined with the width and the same offset would certainly cause tire-to-body contact.
This doesn't even address the tire pressure monitoring system thread (that's been already mentioned in this thread).
Kozmotoo is offline
post #7 of 8 Old 12-26-2006, 06:11 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Kozmotoo
I just wanted to say "Thanks" for your input on these tire topic! You certainly seem to know what you're talking about and I, for one, appreciate the straight forward information
Your profile says that you have a Patriot Are they really out or is yours on order? Either way, happy to have you around
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #8 of 8 Old 12-26-2006, 10:55 PM
Kozmotoo
I have a Patriot Limited AWD on order. I expect it no later than (late) March.
Kozmotoo is offline
Optional tires/wheels for MK's (pg 6 for sizes) Portyansky Jeep Compass & Patriot Forum 264 04-25-2016 05:12 PM
snow tires for compass frumpy Jeep Compass & Patriot Forum 7 11-04-2009 10:04 PM
Will regular old XJ/ZJ rims fit with what size snow tires? eshew Jeep Compass & Patriot Forum 2 10-29-2009 01:02 PM
Remote Starter & Snow Tires greencompass Jeep Compass & Patriot Forum 2 10-18-2009 05:50 AM
looking for wheels and tires nick8387 Jeep Compass & Patriot Forum 0 05-12-2009 09:43 AM
