Starting problems - JeepForum.com
post #1 of 8 Old 01-09-2010, 11:44 AM Thread Starter
zing43
Starting problems
I have an 07 compass limited with 4x4. a lot times when I pull and turn off the car for a couple of minutes and hop back in, the car will not start on the first try, on the second try it hesitates and then catches and starts. Anyone else have this problem
zing43 is offline
post #2 of 8 Old 01-09-2010, 01:16 PM
cactus_jack
sometimes mine does that. I was due for new plugs anyway so I went ahead and changed them, didn't really make a noticable difference. Could just simply be flooding out from already having fuel in the system and then starting again so soon with the auto choke. I know it sounds strange for a fuel injection engine to flood out, but it's possible
CACTUS_JACK
98 XJ Sport Budget Build
cactus_jack is offline
post #3 of 8 Old 01-09-2010, 02:47 PM Thread Starter
zing43
I only have 24k on it, not time to change the plugs yet. Anyone else have the problem and got it fixed
zing43 is offline
post #4 of 8 Old 01-09-2010, 02:50 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Does it NOT want to spin over or does it crank without firing?
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 8 Old 01-09-2010, 04:13 PM Thread Starter
zing43
cranks without firing
zing43 is offline
post #6 of 8 Old 01-10-2010, 05:21 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I thought of this too. The chip in the key is starting to go bad? Try a different key.
There are too many listings in the FSM to list on here and all require a scan tool to read the DTC.
The only one that I saw that mentioned an intermittent fail like your having has to do with the Transmission Range Selector and the Totally Integrated Power Module. The next time it happens try wiggling the gear shift to see if the connection there could be faulty. Otherwise you'll need to start checking for bent or corroded pins on those connectors.
Do you have access to someone who can pull up the codes? If we had a code we can get the circuits posted up for you.
Other causes, but they don't mention "intermittent" are:
SHORT TO GROUND ON (F100) FUSED IGNITION SWITCH OUTPUT (RUN) CIRCUIT
SHORT TO GROUND ON (F929) FUSED IGNITION SWITCH OUTPUT (RUN) CIRCUIT
A/C HEATER CONTROL
COMPASS MODULE
SHORT TO GROUND ON THE (F996) FUSED IGNITION SWITCH OUTPUT (RUN/ACC) CIRCUIT
SHORT TO GROUND ON THE (F985) FUSED IGNITION SWITCH OUTPUT (RUN/ACC) CIRCUIT
SHORT TO GROUND ON THE (A999) FUSED B+ CIRCUIT
SUNROOF MOTOR
A/C POWER OUTLET
REAR WIPER MOTOR
DOME LAMP
INVERTER MODULE
(F937) FUSED IGNITION SWITCH OUTPUT (RUN) SHORTED TO GROUND
(F936) FUSED IGNITION SWITCH OUTPUT (RUN) SHORTED TO GROUND
HEATED SEATS MODULE
CABIN HEATER RELAY NUMBER 1
CABIN HEATER RELAY NUMBER 2
(F901) FUSED IGNITION SWITCH OUTPUT (UNLOCK-RUN-START) CIRCUIT SHORT TO GROUND
TERMINAL DAMAGE OR CORROSION
HIGH RESISTANCE ON THE (F200) FUSED IGNITION SWITCH OUTPUT (RUN-START) CIRCUIT
OCCUPANT RESTRAINT CONTROLLER (ORC)
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #7 of 8 Old 01-10-2010, 07:03 AM Thread Starter
zing43
I have a 5 speed, I will try using a different key for a while, but would it still crank and not fire if any of the those things were the problem. I do not get an engine light problem, so would there still be codes.
zing43 is offline
post #8 of 8 Old 01-10-2010, 08:11 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Yes, there could still be a code, just not an MIL. According to the FSM all of those things mentioned above will fall under 5 or so different "Bxxxx" codes with several possibilities in each group.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
07 Jeep compass starting problem anthonylee Jeep Compass & Patriot Forum 4 04-07-2009 04:24 PM
key-ignition problems? mashnost Jeep Compass & Patriot Forum 12 12-29-2008 01:29 AM
alternator problems umopp Jeep Compass & Patriot Forum 0 12-17-2008 03:02 AM
DVD NAV Display Problems ryotito Jeep Compass & Patriot Forum 2 09-08-2008 05:45 PM
07 Compass with BA sound...jvc HU problems.. evillilsf Jeep Compass & Patriot Forum 8 03-17-2008 05:28 PM
