Speed / Cruise Control Installation - Page 5 - JeepForum.com
post #61 of 125 Old 03-14-2008, 03:45 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Cheers Merlin! I merged the threads.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #62 of 125 Old 03-14-2008, 05:08 PM
scotty1980
It helps a little, but i still don't understand how i can tell if the wiring is already installed. Do i have to take the wheel off to see? It sounds like its installed on most everybodys patriot/compass.
scotty1980 is offline
post #63 of 125 Old 03-14-2008, 05:26 PM
merlinTec
merlinTec's Avatar
Hi
Just remove the cover around the steering and look at connection C2 as posted by Gramps on page 2. look for the speed control wires in pin 4,5 and 6 if you have them it an easy job.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #64 of 125 Old 03-14-2008, 06:40 PM
Jeepster55
i don't know if this has already been posted, but if so, then 'MY BAD'.
the Compass CC kit and the Patriot CC kit are TWO ENTIRELY DIFFERENT kits. makes no sense to me, since they are both MK's, but who knows.
my Compass kit consisted of only 3 parts and was a simple 'plug and play'. the Patriot kit, according to the EPC pic, seems to be a bit more complicated with many more parts.
just thought you might like to know.......
Jeepster55 is offline
post #65 of 125 Old 05-15-2008, 02:05 PM
ggbb415
Hi,
I am installing one by on my compass. I couldn't pull the steering wheel off last time so I put everything back in. I borrowed a steering wheel puller from ad autoparts but it is the kind with the bolts, and it doesn't seem to be the right one to use. Those of you who have done it: did you use a puller with the hooks to hook up the two holes on each side of the retaining bolt? I think everything will be easy as soon as I get the wheel off....
ggbb415 is offline
post #66 of 125 Old 05-15-2008, 09:57 PM
Jeepster55
Originally Posted by ggbb415 View Post
Hi,
didn't USE a puller. once i removed the air bag, i removed the nut, marked the wheel and the shaft so that i can line it up later, and then just simply pulled on the wheel until it came off. that was it.
post #67 of 125 Old 05-17-2008, 03:52 PM
ggbb415
The wheel will come off for half an inch and it stopped there. Even using a puller wouldn't pull it off (the puller started to wear out so I stopped). Why is that??
ggbb415 is offline
post #68 of 125 Old 05-17-2008, 06:17 PM
ggbb415
I finally got the steering wheel off and installed it. It works perfect.
I pulled the wheel off by using a steering wheel puller with the "GM steering wheel puller legs" (part# 3510). I think I will never pull the wheel off by myself. It seems to be really tight, and even the puller itself is worn out after I pulled the wheel. I suggest NOT to put the retaining nut back in the hole for puller to stand on, because that may destroy the thread. I used the piece of metal came with the puller legs.
The information on the forum really helped a lot. Thanks much for sharing your experiences.
ggbb415 is offline
post #69 of 125 Old 01-01-2009, 06:39 PM
ajkst1
2007 MK Compass
first, let me answer the previous question that i said i would;
Mopar Speed Control Kit....List Price $225.00 Dealer Cost $169.00
NOW, for the really GREAT NEWS!!! (if you haven't already purchased a kit)
the kit consists of 3 parts
switch......................PN 4671929AA which has a List Price of $17.95
wire harness....................PN 68036592AA with a List Price of $65.75
steering wheel cover...PN 1EB85XDVAB (GRAY) or
PN 1EB84DK7AB (Beige)...........................with a List price of $65.95
this is all that is in the kit ( i have verified this with my own 4 eyes)
as you can see, even if you pay LIST PRICE, when you purchase these parts separately, your total is 'only' $149.65, a saving of over $75.00!!!!
note: part of the savings is that with the kit you get BOTH the gray and beige steering wheel covers, but who needs BOTH? just buy those parts and make your own kit.....that's what I'M DOING!!!!!
GO FORTH WITH YOUR INSTALL AND SAVE $$
P.S. also, the PN for the wiring harness is updated and is the same harness as used on the Limited models with Remote Radio Control. with this harness, i 'believe' that the radio controls will work when i install the Leather wheel as i have planned.
NOTE: the kit does supply you with 2 screws to mount the CC switch into the wheel. you can pick these up at any hardware store for less than a $1. installing mine on 1/7/08
Do you know what size those screws/bolts (and any associated nuts) were? I'm looking to do this install and want to have everything ready to go when I do the install.
ajkst1 is offline
post #70 of 125 Old 01-01-2009, 07:33 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Jeepster hasn't been around for a while. If you go here and download the parts book from the link in the 3rd post it will tell you just about all the nuts and bolts used.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #71 of 125 Old 01-02-2009, 02:34 PM
ajkst1
2007 MK Compass
Gramps,
I found the kit in the parts book, but it lists "SCREW" without any sizes. It does share a part number with the switch, so I'm guessing it comes with it. Also, the speed control kit for the Compass (the '07 at least) only needs 3 of the 8 parts listed in the parts book.
Current Prices (as of 1/2/09) for the 3 parts you need for an 07 Compass are:
Switch PN# 4671929AB $18.85
Cover PN# 1EB85XDVAB $69.05 (Grey) (Beige: 1EB84DK7AB $69.05)
Wiring PN# 68000462AB $63.65
Total: $151.55
Kit: $231.00
The kit includes both covers (why? who knows.) leading to the $70 difference between buying the parts seperately and buying them as a kit. Thanks Gramps for the parts book link!
ajkst1 is offline
post #72 of 125 Old 01-13-2009, 06:11 PM
ajkst1
2007 MK Compass
Well, I purchased the switch, cover, and wiring harness seperately. It turns out that the cover doesn't have the pre-cut hole anymore unless you purchase the kit. So I'm going to cut the hole in the cover myself and save another $70.
Funny how things work out.
ajkst1 is offline
post #73 of 125 Old 01-08-2010, 04:43 PM
cactus_jack
just ordered the parts needed for my 08 Compass to install cruise. Just to open the thread back up for those who need it, the part numbers and prices are below (ordered from Mopar Parts America)
Switch----4671929AA $7.44
Harness----68000462AB $46.52
Plastic----1EB85XDVAB $49.91
Shipping: $11.43
TOTAL: $115.30
Dealer priced me $250 something
CACTUS_JACK
98 XJ Sport Budget Build
cactus_jack is offline
post #74 of 125 Old 01-08-2010, 04:56 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
You are the busy one! Do you have a heated shop? It's only 14 degress there, about like here, and I'm freezing my ears off!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #75 of 125 Old 01-08-2010, 05:34 PM
cactus_jack
oh yea, it's cold here. I have parts piling up and nowhere to put them on, lol. I may have a friend willing to let me use his garage. I'm just getting my parts in so I can spend a whole weekend working on my ride
CACTUS_JACK
clock spring , clockspring , compass , cruise control , patriot , speed control , steering wheel
Cheapest price for cruise control Jawa78 Jeep Compass & Patriot Forum 4 11-16-2009 06:39 PM
Went for a Cruise... collins1888 Jeep Compass & Patriot Forum 0 06-02-2009 08:03 PM
cruise control with 5 speed Transmition? etovar Jeep Compass & Patriot Forum 9 10-09-2008 02:07 PM
Cruise Control Gentleman Jeep Compass & Patriot Forum 4 04-04-2008 07:16 AM
Mysteries of the Jeep Speed Control Stargazer79 Jeep Compass & Patriot Forum 2 03-19-2008 09:29 PM
