-   Jeep Compass & Patriot Forum (http://www.jeepforum.com/forum/f98/)
-   -   Speed / Cruise Control Installation (http://www.jeepforum.com/forum/f98/speed-cruise-control-installation-452477/)
soycap 08-20-2007 11:47 PM
Anybody install one of these units?
http://www.justforjeeps.com/speedcontrol3.html
I have installed many car stereos, amps, speakers, and accessories since I was a kid, but I have never taken apart a steering wheel before, and blowing the air bag does kind of scare me.
I would like to get some idea of the difficulty involved for the entire install. I have read that some jeeps are pre-wired for speed control and some are not. Anyone know how to tell on a Compass?
The dealer wanted $495 for parts and labor, but I would rather put that $300 to better use and save a trip to the dealer.
stevns31 08-24-2007 06:09 PM
cruise
hey i bought mine from dealer it came with instructions
just unhook neg battery cable
there is two bolts on each side of stering wheel remove them and the air bag will come out then there is one bolt and steering wheel comes out
the rest is simple
just follow the step by step instructions
it took me 15 min and was real easy saved me 250 dollars
the dealer lied and told me i would have to reprogram the computer '''''''wrong just plug it up and works great
merlinTec 08-25-2007 03:28 AM
Hi
Fitted a unit to a 06 PT 2.4 one of the easiest jobs to do.
Regards,
Merlin
soycap 08-26-2007 11:04 AM
Awsome! I actually ordered mine last week. I'll post some pics when I'm done.
soycap 08-28-2007 09:07 PM
Done. It was super easy and the instructions were very easy to follow.
I have not been here 30 days yet and cannot post pictures in the forum, so I have posted pics here:
http://www.boodaw.com/gallery/main.php?g2_itemId=2416
BuzzDog 08-29-2007 06:59 AM
I laugh at how easy it is to install cruise control these days. Unlike the days when speedometers used mechanical drives, it seems as though all of today's vehicles have electronic speed sensors that are integrated into many functions. It also looks as though manufacturers have moved toward "universal" wiring harnesses that have connections for every possible option, as well as modular ones that you can "plug into."
Adding cruise used to be a REAL pain...you had to add magnets and a sensor to a driveshaft (which measured revolutions), AND gizmo that used a chain/cable to tug or release the throttle (which controlled your speed). And a wire to the power supply, and a wire to the ground, and a wire to the switch, and a wire to the speed controller, and a wire to the speed sensor...and, well, you get the idea.
Gramps may remember this, as well...in the "good old days," it wasn't nearly as simple. For example, to get a new, reproduction wiring harness for my vintage car, you have to know body style, as well as whether it had turn signals, heater, radio, etc. You see, you didn't get certain wires on the harness if you didn't order a particular item! Guess the manufacturers finally figured out it's less expensive to have one harness and to let the wires just sit there if they're not used. On top of that, it seems like many vehicles now use a bus that allows one wire to carry the signals and power for multiple items.
I, for one, do not always long for "the good old days!" Great to know that your installation went well...congratulations!
Laloggia 08-29-2007 08:22 AM
Heres a pic for those interested!
http://www.autotrucktoys.com/jeep_co...7373C5270.aspx
Gramps 08-29-2007 08:12 PM
Glad to hear that it went well for you! Not like the HID's. :(
BuzzDog,
Go back to even earlier, Ford Model A, throttle lever on the column, just opposite of the spark advance. A brick on the gas pedal worked too. Although hitting the brakes didn't disengage those. :laugh: Ya, the good old days.;)
Jeepster55 12-22-2007 07:18 AM
Adding Cruise to Your "MK"?
has anyone, or is anyone thinking about, adding the Mopar Accessory Speed Control Kit to their Compass or Patriot? i have the "D" Package Compass (no power accessories, no CC) and this is one option i would like to have. well, that and the Leather Steering Wheel.
after checking, the contents of the kit are as follows; Switch, steering wheel harness (for inside the wheel), 2 screws and a new cover for the back of the steering wheel. apparently the vehicle is already 'pre-wired' and uses the same clockspring. a tech at work told me that he just has to pull the wheel, install the switch, wires and new back cover and reinstall the wheel. book shows only .4hr to do this. then the vehicle has to be reprogramed and the tech goes online to Mopars DealerConnect to 'add' the option into their system. seems simple enough.....
this is what i'm doing, BUT with a twist. i'm also replacing the steering wheel (since it has to come off anyway) with the Leather Wheel. but that one has holes in it on the back side of the wheel for remote radio controls. so here's MY QUESTION....
does anyone know 'if' i switch wheels and add the radio controls, if they will ACTUALLY WORK with my radio? any additional programming to be done by the tech? just thought i would try to get a 'heads up' on this before i present it to my tech at work.
anyone??????
Gramps 12-22-2007 08:19 AM
Not sure if this should be with the Cruise Control thread or in one of the many audio threads. Let's try here and maybe Merlin can help?
Jeepster55 12-22-2007 10:36 AM
thanks....we'll see!
after reading some of these posts, i'll be fine doing it myself. maybe i'll even get lucky and the remote radio controls will work, ya think?;)
merlinTec 12-22-2007 10:47 AM
Hi
You may need a new steering control module but first I would check the wiring is there for the radio control at plug C2 of the steering control module.
1 X20 20GY/WT RADIO CONTROL MUX
2 Y13 20DG/RD RADIO CONTROL RETURN
3 X3 20DG/VT HORN SWITCH SENSE
4 V72 20OR/VT S/C SIGNAL 2
5 V937 20VT/LG S/C SWITCH GROUND
6 V71 20VT/OR S/C SIGNAL 1
This goes though the module to plug C5 behind the air bag
1 X20 20GY RADIO CONTROL MUX
2 Y13 20BK RADIO CONTROL RETURN
3 X3 20DB HORN SWITCH SENSE
4 V72 20PK S/C SIGNAL 2
5 V71 20VT S/C SIGNAL 1
6 V937 20YL S/C SWITCH GROUND
I am sure it would be just plug and play just like the CC and you don’t have to go onto dealer connect to turn on CC if it doesn’t come on straight away hold the brake on then press and hold the CC on switch.
Regards,
Merlin
CharBroiled 12-22-2007 01:09 PM
yeah I put one in a 70 dodge dart back in the day, mine was vacuum operated though.. magnets, pickup, brake cut out switch, vacuum tie in, throttle linkage tie in, mount the stalk, vacuum motor, wire it all up.. etc yup the good ole days heh
glad it went well.
seems a lot of add on car stuff is kinda plug and play now.
Jeepster55 12-22-2007 02:08 PM
glad it went well.
HA HA...my first car? 70 Dodge Dart Swinger..of course, NO CRUISE but then again i was a kid. what the he!! did i need CC for anyway?! ok, enough memory lane.....gotta plan my CC install. first, i had better ORDER my kit, huh? :D
THANKS!
Jeepster55 12-22-2007 02:10 PM
oh, and thanks Merlin......i'll check it out. if it doesn't work, eh, so what. at least i have the CC and my Leather Wheel.....i REALLY like the feel of leather. makes me want to ....oh, sorry. that's another forum all together! ;)
The time now is 09:46 PM.
