size of rear rotors - JeepForum.com
post #1 of 11 Old 06-26-2010, 08:53 AM Thread Starter
howdy246
2008 MK Compass
size of rear rotors
Any one know how to tell the difference in the size of the rear rotors? I went to buy some new ones and found out that they could be 11.89" or 10.313"?
howdy246 is offline
post #2 of 11 Old 06-26-2010, 09:20 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
All of my data for 2007 - 2010 calls for 11.5 vented on the front and 10.3 solid on the rear.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 11 Old 06-26-2010, 10:33 AM Thread Starter
howdy246
2008 MK Compass
Thanks Gramps, I just did the front brakes and now want to do the rears, but the web site I'm ordering form has the two different sizes. I've checked several other web sites and everyone else lists just the 10.3" so I'll order those.
By the way great prices here. Discount Auto Parts Canada - Auto Parts Warehouse | Complete Struts | Hub Bearing Assembly | Brake Pads and Rotors | Starters and Alternators | Prime Choice Auto Parts . I wasn't sure of the quality of the parts but they seem pretty good. I used their parts for the front brakes. I got 67,000kms out of the original ones so I'll see how much I get out of theses ones.
howdy246 is offline
post #4 of 11 Old 06-26-2010, 10:47 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
After doing my fronts I checked the prices on the rears...cheaper is a good thing!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 11 Old 07-02-2010, 05:49 PM
tfmr
2010 JK Wrangler
in the 2.0 CRD patriot the rotors have the same size? can't find that info anywhere
tfmr is offline
post #6 of 11 Old 07-02-2010, 07:45 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I checked the Jeep International and the UK brochure and although they did not give a specification they didn't show a difference between petrol and Diesel. I'll tr and check with merlinTec and see if he can help.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #7 of 11 Old 07-03-2010, 11:37 AM
merlinTec
merlinTec's Avatar
Choice are
Referred to as "16-inch" because they are designed to fit inside 16-inch or larger wheels. Actual front rotor diameter is 294 mm (11.5 in.). Actual rear rotor diameter is 302 mm (11.8 in.).
Referred to as "14-inch" because they are designed to fit inside 14-inch or larger wheels. Actual rotor diameter is 262 mm (10.3 in.).
If you post the last 9 of your vin I will look up the jeep part number and you may be able to cross reference but I am sure all CRD's are the larger rear discs.
Note: there is a TSB 05-001-09 for European market for front brake pads
Part number
68020494AB Pad, Front Brake, and 5105514AA Rotor
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #8 of 11 Old 07-04-2010, 05:38 PM
tfmr
2010 JK Wrangler
thanks for the info!
Since here we only have the 17" wheels version, the rotor sizes are 294mm in front and 302mm in the rear
about the TSB, i didnt know but i've the 2008 model and made the 15k km and the 30k km service (a month ago) and they (jeep) didn't say anything about "brake" problems... the pads/rotors still the ones that came stock and now the warranty is over (only 2 years)
i asked about the size, because in big distance or hard braking, the jeep makes a "thunder" noise, and i thought it was due to pad/rotor getting hot...
since the warranty is over, what do you thing about changing the front rotors to perforated ones(same size), and new pads? only when they need to be replaced!
the last 9 of vin: 38D525393
tfmr is offline
post #9 of 11 Old 07-05-2010, 03:09 PM
merlinTec
merlinTec's Avatar
Hi
rear pads 68028671AA, rear rotor 04743999AA based on you vin. front part numbers same as I posted above. I can't comment on other disc as I only know dealer fitment. I will leave after market stuff to others to comment on.
Regards,
Merlin
post #10 of 11 Old Yesterday, 01:07 AM
ekkirus
Originally Posted by merlinTec View Post
Hi
Regards,
Merlin
Hi merlinTec
Not sure is that thread still active but
Could you please let me know rotor sizes & Part number of my newly purchased 2012 Jeep Patriot 2.4L
I have 16" rear Wheels and Last 9 on my vin - XCD617585
I am located in US right now.
ekkirus is offline
post #11 of 11 Old Yesterday, 01:48 PM
MrBill345
Try this: measure the circumference with a soft tape.
The circumference is Pi times the diameter or C = Pi * D
Solving for diameter: D = C / Pi
Which means a Circumference of 37.4" (948.8mm) means Diameter is 11.89" (302mm) and a Circumference of 32.4" (823.1mm) means Diameter of 10.313" (262mm). Hope this helps.
MrBill345 is offline
brakes , compass , patriot , rear brakes , rotor
Rear ended - rear bumper question handyman98 Jeep Compass & Patriot Forum 4 05-12-2009 10:19 AM
Compass Headlight size? fuzzyweis Jeep Compass & Patriot Forum 0 04-24-2008 09:17 PM
Compass rim size jojoneveu Jeep Compass & Patriot Forum 4 12-19-2007 08:32 AM
Full Size Spare snood Jeep Compass & Patriot Forum 8 10-30-2007 02:05 PM
couple of comparison pics xj size vs patriot size madrabbitt Jeep Compass & Patriot Forum 10 05-28-2007 12:40 PM
