Shake in steering wheel on deceleration - JeepForum.com
post #1 of 9 Old 05-25-2010, 11:51 AM Thread Starter
Argent33
2014 JK Wrangler
2007 5spd 4x4 29XXX miles
Sometimes - when I decelerate my steering wheel will shimmy left/right a bit
Also there appears to be a rotational related sound coming from the front passenger side (I believe them to be related)
any thoughts or suggestions as to what might be wrong before I try to explain it to the dumbership?
~Paul
-[O l l l l l l l O]- 2014 Freedom Edition JKU - Hydro Blue 6-Spd
Argent33 is offline
post #2 of 9 Old 05-25-2010, 12:01 PM
schoat333
2008 MK Patriot
Sounds like warped brake rotors. Do you feel a pulsation in the brake pedal while stopping?
schoat333 is offline
post #3 of 9 Old 05-25-2010, 12:05 PM Thread Starter
Argent33
2014 JK Wrangler
Yes I do feel it in the brake pedal too
~Paul
Argent33 is offline
post #4 of 9 Old 05-27-2010, 07:53 PM
fortuneer
fortuneer's Avatar
2007 MK Compass
Sounds exactly like a warped rotor. Had that same issue on several vehicles over the years. Usually comes from too hard a stop from too fast a speed. Even anti-lock brakes have their limits. The rotors can actually heat up so quickly that the metal will warp causing shimmy and/or pulling to one side (the brakes will now be out of balance with each other) as well as pedal pulsations. So far managed to avoid that this time around.
"There's gold in them hills" (and I'm still stuck in Florida!) ...well, in south Miss now, lol
Black '07 Compass Sport 5-speed 4X4 ("Fortuneer"), K&N filter, cat-back exhaust; RR lift, sunroof, trailer tow group, Boston Acoustic audio, sport bars, rear taillight guards, more to come... Finally got it back from the wife so I can let my Neon R/T rest for a rebuild.
fortuneer is offline
post #5 of 9 Old 05-30-2010, 10:50 AM
deepnite10
the rotors will become uneven with use..its unavoidable..
it can be easily remedied though..but, it ll usually require the
pads replaced and rotors turned..turning is mearly a grinding
procedure to make sure the rotor is trued..
warping can be avoided by following the proper break in period
and procedures recommended in the manual or from the brake shop..
what can also cause warping is fast exposure from hot to cold..
after having to brake frequently the rotor becomes hot and soft..
if you wash your car..a cold spray on the rotors can cause them to
warp if you don t allow time for them cool..happens alot at those
gas station car wash s..people come back after a hard day of driving
and just want to clean up their cars befor returning home..brakes hot, into the car wash..come out and the rotors have warped to a certain
degree..and its only a matter of time befor they start experiencing same
problems as pulsating sensation when applying the brakes
in your case its sounds a little more serious since your experiencing
a strong vibration with having to apply the brakes..
deepnite10 is offline
post #6 of 9 Old 05-31-2010, 09:19 AM
Jawa78
2008 MK Compass
yeah resurface the rotors , As an owner of a 99 WJ and 08 MK I know that senationwhen it gets really bad you get strong forarms holding the wheel straight.
Jawa78 is offline
post #7 of 9 Old 05-31-2010, 10:29 AM
deepnite10
strongly recommended to replace the brake pads as well..they and the
rotors are already experiencing uneven wear..by not replacing the pads your going to be putting an uneven wearing pad surface on a trued rotor..back to
square one again..
post #8 of 9 Old 07-06-2010, 04:20 PM
spencernj
I had the same and it was fixed with new discs. They probably could have been turned but the work was done by the dealer$hip and they said they had to be replaced (at my cost) to maintain the warranty
Current: 1998 XJ 4.0 Ltd Grey/Blue, 2008
Past: 1998 XJ 4.0 Ltd Green, 2005 Grand Cherokee Ltd Black, Patriot 2.0 CRD Ltd Silver
spencernj is offline
post #9 of 9 Old 07-22-2010, 06:14 AM Thread Starter
Argent33
2014 JK Wrangler
Finally got it in to the dealer
they replaced the lower control arms under warranty, and also turned the rotors, and replaced the pads on the front.
They also said I needed new tires at all the corners (not surprising given they are the crappy Firestones that came with it) - I have a new set of Yoko AVID ENVigor's 225/60R18's waiting to be mounted and balanced now
~Paul
Argent33 is offline
brakes , compass , deceleration , patriot , rotors , steering shake , warp rotors
Steering Wheel Audio Controls wesleyd Jeep Compass & Patriot Forum 6 11-30-2009 06:23 PM
Steering wheel pulling on Decel jpi54 Jeep Compass & Patriot Forum 4 09-10-2009 04:22 PM
Steering wheel slightly to the left?? cactus_jack Jeep Compass & Patriot Forum 6 08-05-2009 08:17 AM
Noisy steering wheel , 2008 compass compasst Jeep Compass & Patriot Forum 3 10-26-2008 07:12 PM
Steering Wheel Audio Controls davep Jeep Compass & Patriot Forum 26 04-21-2008 05:15 PM
