Set alarm and horn goes off minutes later - JeepForum.com
post #1 of 3 Old 08-06-2010, 01:38 AM Thread Starter
ajeep4you2
My mother in law 07 compass alarm goes of after its set with the FOB. Also I notice to that if you push the lock door button and closed the door it will also make the alarm go off? But if I push down the door lock arm on door and alarm won't go off? Is this a moduler going bad? Should I disconnect the battery and see if it will go away? Mike
ajeep4you2 is offline
post #2 of 3 Old 08-06-2010, 02:44 AM
merlinTec
merlinTec's Avatar
Hi
do you have internal sensor? press the lock button 3 times to turn off internal sensing if this stops it then you may need a software update for the sensor.
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #3 of 3 Old 08-06-2010, 10:46 PM Thread Starter
ajeep4you2
Today I sat in the jeep I noticed that the dealer installed a alarm light under dash.. The light is blinking little fast
Also when I sat there I set the alarm and the light did not change. The dealer we got it from went out of bussiness almost two years ago.
alarm , alarm system , compass , mk , patriot
patriot horn jdaddy42 Jeep Compass & Patriot Forum 7 10-13-2012 08:15 AM
Where is Compass horn located? fortuneer Jeep Compass & Patriot Forum 7 05-28-2010 10:15 PM
Horn dying... tazman900 Jeep Compass & Patriot Forum 3 04-29-2009 04:08 PM
Remove horn on lock without EVIC f_chabot Jeep Compass & Patriot Forum 5 08-20-2008 07:30 PM
Security Horn andyqbui Jeep Compass & Patriot Forum 29 07-16-2008 08:21 PM
