Seat belt/ head rest issue - JeepForum.com
post #1 of 6 Old 09-21-2012, 09:19 AM Thread Starter
huske
My Mom was being a geneuis one day and had my son in the front seat so she put the seat belt around the head rest. She must have pulled it all the way out when putting it on because i locked up. so now we cant pull it out and we cant get it to go back in because its locked around the head rest. Can we take the head rest right out or how do we fix this? any ideas?
thanks.
huske is offline
post #2 of 6 Old 09-21-2012, 09:24 AM
IRSmart
2015 KL Cherokee
first off, with all of the airbags in the front of your car, and the active head restraints, you should count your blessings that your son was not injured due to your mom's negligence.
that said, can you tilt/slide the seat to give some slack to the seatbelt?
IRSmart is offline
post #3 of 6 Old 09-21-2012, 12:18 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I'd never taken mine out and had to try that. I did it from the back seat. I tilted the front seat back, pushed in on the 2 tabs at the base where they slide into the top of the seat and it pulled right out.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #4 of 6 Old 09-21-2012, 12:31 PM Thread Starter
huske
Yea we are lucky hes fine and. Tried to move the seat but she has pulled it and has it so thought its actually almost breaking the seat at the moment. I tried pulling the head rest but it will only go up so high then stops
huske is offline
post #5 of 6 Old 09-22-2012, 07:32 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
It sounds like you may have to remove the seat belt.
1. Before proceeding with the following repair procedure, review all warnings and cautions.
2. Using a trim stick C-4755 or equivalent, remove the seat belt anchor trim (3).
3. Remove the bolt (2) and separate the seat belt anchor (1).
You shouldn’t need the rest of this info but just in case you do:
WARNING: The Seat Weight Sensor is a sensitive, calibrated unit and must be handled carefully. Do not drop or handle roughly. If dropped or damaged, replace with another sensor. Failure to follow these instructions may result in personal injury or death.
WARNING: The front passenger seat must be handled carefully as well. When removing the seat, be careful when setting on floor not to drop. If dropped, the sensor may be inoperative. Failure to follow these instructions may result in personal injury or death.
WARNING: When the seat is on the floor, no one should sit in the front passenger seat. This uneven force may damage the sensing ability of the seat weight sensors. If sat on and damaged, the sensor may be inoperative. Failure to follow these instructions may result in personal injury or death.
4. Remove the bolts (4).
5. Tip the seat back and disconnect the electrical connectors.
6. Remove the seat.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #6 of 6 Old 03-15-2015, 09:06 AM
chappyz24
On the 2014 patriot you raise the headrest as high as you can. 1 side has a button for raising or lowering the headrest, on the other side in the same spot a button should be you will see a pin hole, use a nail or pin and push it in the hole, this will release the headrest you can then remove it and unwrap the seatbelt. (the 2014 has a wire connected to the headrest.-for a sensor or airbag?? You should be able to pull it out far enough to remove the belt without unplugging the wire harness. When done carefully push wire back down the hole and re insert the headrest)
chappyz24 is offline
Serpentine Belt Removal hectorav Jeep Compass & Patriot Forum 27 06-03-2016 02:58 PM
timing belt compass diesel ukjeepcompass Jeep Compass & Patriot Forum 2 03-05-2011 04:10 AM
Annnoying seat belt ding eze07mayhem Jeep Compass & Patriot Forum 34 05-23-2010 03:36 PM
Serpintine Belt & Timing chain cuemark8 Jeep Compass & Patriot Forum 1 03-14-2010 03:59 PM
Seat Belt Wear snood Jeep Compass & Patriot Forum 0 09-01-2009 10:43 PM
