Rim Size issues!!!! - JeepForum.com
post #1 of 3 Old 10-04-2014, 07:49 PM Thread Starter
zblitz45
2014 MK Patriot
Rim Size issues!!!!
hey guess, i have a 2014 jeep patriot and I'm having a little trouble with rim size. I'm looking at Vossen CV3 19x8.5. my problem is that apparently they won't fit. what i don't understand is that the website say that the 20x8.5 with a +38 offset will fit but the two 19x8.5 rims that match my bolt pattern are +15 offset and +32 offset. why would a 20x8.5 with a +38 fit but 19x8.5 and +32 not fit?????? please help
zblitz45 is offline
post #2 of 3 Old 10-04-2014, 11:48 PM
DEF1ANT
2014 MK Compass
https://www.rimsntires.com/specspro....&text1=&text2=
On the link above, I made you a comparison with the 17" OEM wheels vs the 19" rims with 235/45 tires, they fit fine on the inside and will stick out 20mm more than the OEM wheels. That 20mm more should not be a problem, unless if you go with a much wider and taller tire, then you might start rubbing the tires when turning.
DEF1ANT is offline
post #3 of 3 Old 10-05-2014, 12:26 PM Thread Starter
zblitz45
2014 MK Patriot
Thank you, this actually helped a lot
zblitz45 is offline
