Replacing Lower Ball Joints on 2009 Patriot - JeepForum.com
post #1 of 12 Old 06-27-2012, 12:15 PM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
So I haven’t been too active due to looking for a house and planning my wedding but my fiancés 09 Patriot has a knocking noise which I knew would either be the Tie rod on the driver’s side or Ball joint. We took it to the dealer for a routine oil change and were told we needed new lower control arms and an alignment so that answered my question. Now I’ve been reading about 8 older threads and apparently I can press out the balljoints which is great. I didnt think they could since my 08 Liberty they cannot. My question is, has the suspension changed on the 09 Patriots or can I still press out the lower balljoint and slap in a greasable Moog? Also if so, I’ve looked on the Moog site and when choosing Compass and model year 09 nothing comes up but choosing Compass and year 08 I get model number MOOG-K500063. Is this the correct one that others have used? Thanks in advance.
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #2 of 12 Old 07-02-2012, 06:34 AM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
Nobody?
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #3 of 12 Old 07-05-2012, 08:47 PM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
130 Views and nobody has done it?
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #4 of 12 Old 07-05-2012, 08:54 PM
95BadBoy
OK - now 131. Still no help.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #5 of 12 Old 07-05-2012, 09:25 PM
FujativeOCR
2011 MK Patriot
I haven't.
FujativeOCR is offline
post #6 of 12 Old 07-05-2012, 10:12 PM
tjkj2002
2002 KJ Liberty
I can tell you that you can press in/out the LBJ's on your KK,for the patriot it does look like you can replace teh LBJ's themselfs and not the whole LCA.
tjkj2002 is offline
post #7 of 12 Old 07-07-2012, 04:51 PM
jharris09
2010 MK Patriot
You can replace just the ball joint but honestly it is a pain. It is much easier to just replace the whole lower control arm with the new ball joint and bushings already installed. You can find the whole assembly on Ebay for like $50.00 up to $100.00+. It is not that hard if you have all the right tools. The parts from 07-10 and maybe beyond are all the same. They probably don't list the newer years because in all reality they shouldn't fail so quickly! Thanks.
jharris09 is offline
post #8 of 12 Old 07-08-2012, 08:34 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I'm not sure how I missed this except for whatever reason it didn't show up as being highlighted (new thread). These are all the same. I don't have access to the later parts books so you can double check with the dealers if you like. Yes the whole assembly is easy to install but you also get the factory, no grease fitting and smaller 'joint' in the process. If you have ever replace the earlier type of ball joints it's just the matter of having a press to R&R the Moog type.
Side note: 'lookers' may not have been members, couldn't post but were still counted.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #9 of 12 Old 07-08-2012, 11:51 AM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
Thanks for the reply fellas!
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #10 of 12 Old 07-31-2012, 12:10 PM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
Thought this might help others get an idea on the process
http://www.moogproblemsolver.com/_pd...K500063_En.pdf
I ordered the parts from Amazon who had them cheapest at 31.00 a piece
http://www.amazon.com/Moog-K500063-B...I26T4UUR78VVJQ
Hoping to tackle the job this weekend. Ill post results.
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #11 of 12 Old 08-01-2012, 09:04 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Thanks for the great find Elt31987! This is going up in the quick links for reference.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #12 of 12 Old 08-13-2012, 07:37 PM
TeHpWNaG3
2007 MK Patriot
Did you do the job yet?
If you haven't already, I can fully recommend that you seek out a "pro" with a hydraulic press to do the pressing for you. If you have a typical hand press and just have to do it yourself, like I did, clamp the control arm in a SOLID vise. Press them out that way. Had to mention that in case you were going to try with your knee.
*Be careful with the old bushings when taking out the control arms. The arm needs to be manipulated just right to come out without jacking up the bushing.
*If you remove the steering knuckle, you could do the whole job on the vehicle, but with all that torque it's dangerous on jack stands. Lift? Sure. Bring your muscles and have a cold beer handy.
*With the new ball joint, grease the control arm opening and the ball joint body. Watch out and don't press too far. As soon as you can see the far side of the retainer groove come through, stop pressing.
*Use a section of 1.5" PVC pipe to dead-blow hammer the boot on. By hand, that F'in thing will make you see the sun go down. The PVC should fit snugly over the boot. Make sure the PVC is smooth around lip so as not to tear up the boot. A little grease will help. My hat tips to anyone who can thumb those on. Video or it didn’t happen.
*Don't over-tighten the grease fittings. Couple turns then orient it in the direction which suits you best.
*Top off the fittings with grease, if you like.
In all honesty, I didn't enjoy pressing them out or in one bit. Someone else may disagree and say it was a piece of cake, but my control arms did NOT like the process.
The ball joints are AWESOME and the overall job was easy, but again, I should have had a shop do the pressing for me. It wasn't fun or worth the savings IMO.
TeHpWNaG3 is offline
Front lower ball joints Rosco11 Jeep Compass & Patriot Forum 0 11-22-2011 11:50 AM
2009 Patriot - Noise at Speed KillingField Jeep Compass & Patriot Forum 3 11-22-2010 12:15 PM
2009 Patriot quality acmf74 Jeep Compass & Patriot Forum 3 08-08-2009 08:22 PM
2009 Patriot window tint? samiebaby1 Jeep Compass & Patriot Forum 1 12-18-2008 02:09 PM
2009 Patriot questions boon4376 Jeep Compass & Patriot Forum 2 09-18-2008 08:03 AM
