replacement for factory sub - JeepForum.com
post #1 of 5 Old 05-13-2012, 11:34 PM Thread Starter
ronjr8102
2007 MK Compass
Fist off I don't know anything about sound systems so please help. I have a 07 with the BA sound system.The sub is blown and wondering if I could just buy a cheap sub to replace it with? I also noticed that there is four wires for the sub and as far as I know dont subs have only two connections? So does tha tmean I cant replace it with an aftermarket sub?
ronjr8102 is offline
post #2 of 5 Old 05-14-2012, 07:36 AM
FujativeOCR
2011 MK Patriot
Dual Voice Coil subs have 2 sets of connections on them. I wouldnt think a factory sub would be that though. Gramps posted a link in one of the other recent stereo threads to some pics of the sub box and how to remove it. I'm not sure it has the standard 8 screws a normal sub has. Also the factory amp is only 90 watts, and the sub I think is an 8".
FujativeOCR is offline
post #3 of 5 Old 05-14-2012, 07:42 AM
FujativeOCR
2011 MK Patriot
Originally Posted by Gramps
Here's some pics of the sub enclosure. Just pull off the side panel and there it is held on by 3 screws.
http://www.jeepforum.com/forum/f98/b...estion-432143/
Heres the link
post #4 of 5 Old 05-14-2012, 09:56 PM Thread Starter
ronjr8102
2007 MK Compass
I got the sub enclosure out and the sub out of it.
Was wondering if I could get an aftermarket sub to replace it with?
post #5 of 5 Old 05-14-2012, 10:35 PM
FujativeOCR
2011 MK Patriot
I dont see why not? If it has the standard 8 screw hole pattern. Were all four wires connected to the sub after you got it out? One of the logistic problems of buying a replacement is figureing out what impedence to get...4 ohm or 8 ohm....to properly match the amp. With a voltmeter and a new factory sub you could test and see what the stock one was....but since its blown that won't work. If I had to guess I'd imagine a 4 ohm sub would work...but thats a guess.
Antenna Mount (factory) snood Jeep Compass & Patriot Forum 3 06-15-2010 08:53 AM
1.8 Billion for Jeep Factory retooling geopa Jeep Compass & Patriot Forum 0 08-13-2008 05:54 PM
Uconnect For A Factory No Factory Install 229bonehead Jeep Compass & Patriot Forum 1 08-10-2008 09:46 PM
Patriot Factory Tow Harness Install Hinterlander Jeep Compass & Patriot Forum 2 05-12-2008 12:30 PM
factory stereo trouble haasamanizer Jeep Compass & Patriot Forum 1 06-22-2007 12:14 AM
