Replacement battery for MK - JeepForum.com
post #1 of 6 Old 06-07-2013, 01:56 PM Thread Starter
Beware
2007 MK Compass
Hi,
I'm assuming we can fit only batteries from group size 25, 75 and 86 onto the battery tray in MK. I wish to know what's the minimum required CCA for the battery?
I'm on my 4th battery now, and it just died...... ok not exactly dead but it's not 'strong' enough to crank the engine
addendum:
Sorry, I actually meant to ask: 'What batteries are you people having?'
Beware is offline
post #2 of 6 Old 06-07-2013, 02:57 PM
jacko15
2014 WK
Sounds like you're hard on batteries. Our factory battery lasted 4 years in our '08 Compass. We replaced it with the same battery. If you want to go a little extreme, may I suggest something like this: http://www.carid.com/2007-jeep-compa...y-4406773.html
Mine: 2014 Jeep Grand Cherokee Overland V/6
ORA II
Hers: 2017 Jeep Compass Latitude 4x4
jacko15 is online now
post #3 of 6 Old 06-07-2013, 03:26 PM Thread Starter
Beware
2007 MK Compass
Yeah that's a good battery with CCA 720 Amps. I was looking at that too but unfortunately I'm unable to get it at my location. I do not know what our factory battery was, as it got swapped out within months after I've got my MK.
Here's my dead battery:
Beware is offline
post #4 of 6 Old 06-07-2013, 04:31 PM
jacko15
2014 WK
450 CCA isn't much. Can you get Mopar original equipment? Just looked at your location, and I'm afraid I probably can't be of much help, but I wouldn't bother with a battery under 600 CCA.
ORA II
post #5 of 6 Old 06-07-2013, 07:47 PM
Redpine
2014 MK Patriot
Note that the OP is in Singapore. What's the climate there and what batteries are available?
My new 2014 Pat with 2.4 l engine comes with a 525 CCA battery. I'm not sure of the group size, but it looks pretty small. Interstate lists it as a group 86, but I have also seen group 25,26, and 35 as fitting (confirm yourself).
Bigger CCA is not always better. With case size remaining the same, a 700 CCA plus battery will have more, but thinner and more tightly spaced plates compared to a smaller CCA battery. The thinner, more tightly packed plates MIGHT have less longevity, especially in hotter climates.
You don't need the higher CCA's in warm climates. So, it's a trade off.
The worst enemies of car batteries are heat and repeated draw down of the battery (lights left on, etc.), which kills them quickly.
I wonder if the location of the Pat's battery contributes to higher heat?
My opinion would be not to go more than one CCA size up (640CCA +/-) because of the plate info given above.
Also, regarding Optima batteries. Since Johnson Controls took over manufacturing of this battery, the internet buzz is that quality has suffered greatly. Just a statement not based on experience. Check it out yourself.
Redpine is offline
post #6 of 6 Old 06-09-2013, 12:46 PM Thread Starter
Beware
2007 MK Compass
I've found a suitable battery after much searching for the past few days
Thanks for all the suggestions, hope this one will last
Beware is offline
