Removing Front Grill and Headlights on Patriot - JeepForum.com
post #1 of 14 Old 03-26-2010, 05:59 AM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
Hey, i usually spend most of my time in the KK section but on my Patriot MK im going to be installing an HID Conversion Kit. Im sure ill figure it out since i ripped my Libertys grill and lights out but anyone have a writeup or pictures of the front grill and headlight removal? Thanks
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #2 of 14 Old 03-26-2010, 06:22 AM
schoat333
2008 MK Patriot
Originally Posted by schoat333 View Post
I did a write up on a patriot specific forum for removing the front bumper/grill (The bumper and grill are all one piece).
I cant link it here, but you can google jeep patriot forum and see what come up.
Didn't know that. Thanks Gramps.
schoat333 is offline
post #3 of 14 Old 03-26-2010, 06:41 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Post #9 and #13 over here. http://www.jeepforum.com/forum/f98/t...ompass-406859/
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #4 of 14 Old 03-26-2010, 06:49 AM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
Gotcha Thanks
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #5 of 14 Old 03-26-2010, 07:19 AM
schoat333
2008 MK Patriot
I guess it would be best if I contribute to this site a little more.
Here is a how to on removing the front bumper cover. (Gramps, feel free to move this to a how-to thread if youd like.)
1st youll need these tools to remove the bumper cover.
7mm socket and ratchet
7mm wrench
10mm socket
screw driver or panel removal tool (for push rivets)
Step 1 remove the 3 7mm screws on the wheel shroud in front of the front tire.
Step 2 remove the push rivet on the inside of the wheel well. (top one on pic)
step 3 remove the 2 push rivets on the bottom of the shroud that attach to the bumper cover.
step 4 pull the shroud back to expose the inside of the bumber cover.
Step 5 remove the 7mm bolt in the corner of the bumper cover connecting it to the fender. also remove the 2 larger push rivets you see in the same area. (second push rivet is behind metal piece to the right in picture)
this is what the larger push rivets look like.
repeat steps 1-5 on the other side.
step 6 romove the air intake upper piece by twisting the two plastic hand screws and remove.
step 7 remove the 2 10mm bolts on the corners of the bumper cover were it meets the fenders under the hood(already removed in picture 1). and also remove the 5 plastic push rivets.
step 8 underneith there is a clip that holds the bumper cover to the chasis. there should be 2 (mine only had one, yeah those cheap.... )
step 9 pull upward on the top part of the bumper cover near the headlight with one hand and pull outward on the corner below the fender at the same time with the other. the bumper will slide forward. only pull it out a few inches at first and then twist the turn signal sockets out of the housings before removing the bumper completely.
a view with no bumper cover.... :wow: p.s the wires hanging are for my aftermarket fog lights.
post #6 of 14 Old 03-26-2010, 09:41 AM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
Perfect, ill post up pics of the lights after i get it installed. Prolly wont be for like another week
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #7 of 14 Old 03-26-2010, 12:06 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Here is a how to on removing the front bumper cover. (Gramps, feel free to move this to a how-to thread if you'd like.)
I put a link in the Quick Links sticky. Thanks for the "How To".
I'll add that some of those "push pins" come out pretty easily if you use a couple of small "electronics size" screw drivers to pry the inner head up. Then the panel remover will pop them right out.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #8 of 14 Old 03-29-2010, 02:07 AM
Tony1911
2007 MK Patriot
An anti-seize spray may also come in handy when removing push rivets. The little buggers can be stubborn sometimes, especially if they have dirt in them.
It's a Jeep Patriot thing. You wouldn't understand.
Tony1911 is offline
post #9 of 14 Old 04-23-2010, 11:57 AM
GNaqua
Originally Posted by Elt31987 View Post
Hey, i usually spend most of my time in the KK section but on my Patriot MK im going to be installing an hid headlight kits. Im sure ill figure it out since i ripped my Libertys grill and lights out but anyone have a writeup or pictures of the front grill and hid kits removal? Thanks
Great set of pictures schoat333, thanks!
GNaqua is offline
post #10 of 14 Old 04-23-2010, 01:13 PM
miketmx
2015 MK Patriot
The parking light lens on the driver's side of our Patriot has a rock chip crack and condensation forms inside the parking light. I hope that I don't have to remove everything just to replace that parking light lens ?? Does it come off with just a flat screw driver applied to the side ??
miketmx is offline
post #11 of 14 Old 05-02-2010, 11:56 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Sorry Mike! I missed this earlier. http://www.jeepforum.com/forum/f98/c...lenses-718996/
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #12 of 14 Old 05-02-2010, 06:15 PM
miketmx
2015 MK Patriot
Thanks Bob. I suppose that the lens on a Patriot is held on by 3 screws just like the Compass but even if it is different, I will still have to remove the wiring connector and bulb according to the writeup. Our old Dodge Caravan had a sliding panel in the wheel well for access to the turn signal bulb but even then it was handier to remove the wheel for starters.
miketmx is offline
post #13 of 14 Old 07-03-2012, 07:28 AM
Dougget
schoat333,
Great write up. I followed it to the letter and had an easy time of removing my grill/bumper. I too only had one clip on the bottom. Really? what do those things cost, maybe $0.20 - $0.30... Oh well.
While my bumper cover was off, I installed an additional horn, three LED marker lights, and a set of driving lights (similar to the "Pilot" lights that have also been written up).
It all went back together well too. Now I just need to finish off the electrical. My lower dash is in pieces now as I look for a good place to put a couple of switches
Thanks again for taking the time to document the process.
Doug
Dougget is offline
post #14 of 14 Old 01-09-2016, 03:39 PM
bjlo4life
hey guys i have a question about a part # i have an 08 patriot and i need the little round metal "push type" lock washers that physically hold the black grill insert onto the front bumper cover. I broke just about every one of them a few years ago and now i need to replace them. any info will help me out. I looked at an exploded view on chryslers website but can't pinpoint which one it is. thanks everyone
bjlo4life is offline
fascia , grille , how to , patriot
CRD Patriot! tfmr Jeep Compass & Patriot Forum 2 02-01-2010 05:15 PM
2008 Patriot Squeaking Front Passenger Seat micbuy Jeep Compass & Patriot Forum 3 05-31-2009 06:45 PM
getting patriot, can't decide color! (how is the patriot?) taseal Jeep Compass & Patriot Forum 20 02-08-2008 11:46 PM
exploded diagram of 07 patriot front end? CharBroiled Jeep Compass & Patriot Forum 2 01-19-2008 06:21 AM
Front Receiver for Patriot? wrightrandy Jeep Compass & Patriot Forum 0 11-30-2007 06:29 PM
