-   Jeep Compass & Patriot Forum (http://www.jeepforum.com/forum/f98/)
-   -   Removing Front Grill and Headlights on Patriot (http://www.jeepforum.com/forum/f98/removing-front-grill-headlights-patriot-999228/)
Elt31987 03-26-2010 05:59 AM
Hey, i usually spend most of my time in the KK section but on my Patriot MK im going to be installing an HID Conversion Kit. Im sure ill figure it out since i ripped my Libertys grill and lights out but anyone have a writeup or pictures of the front grill and headlight removal? Thanks
schoat333 03-26-2010 06:22 AM
Originally Posted by schoat333 (Post 9161815)
I did a write up on a patriot specific forum for removing the front bumper/grill (The bumper and grill are all one piece).
I cant link it here, but you can google jeep patriot forum and see what come up. ;)
Didn't know that. Thanks Gramps.
Gramps 03-26-2010 06:41 AM
Post #9 and #13 over here. http://www.jeepforum.com/forum/f98/t...ompass-406859/
Elt31987 03-26-2010 06:49 AM
Gotcha Thanks
schoat333 03-26-2010 07:19 AM
I guess it would be best if I contribute to this site a little more.
Here is a how to on removing the front bumper cover. (Gramps, feel free to move this to a how-to thread if youd like.)
1st youll need these tools to remove the bumper cover.
7mm socket and ratchet
7mm wrench
10mm socket
screw driver or panel removal tool (for push rivets)
Step 1 remove the 3 7mm screws on the wheel shroud in front of the front tire.
http://i6.photobucket.com/albums/y23...moved/0br1.jpg
Step 2 remove the push rivet on the inside of the wheel well. (top one on pic)
http://i6.photobucket.com/albums/y23...moved/0br2.jpg
step 3 remove the 2 push rivets on the bottom of the shroud that attach to the bumper cover.
http://i6.photobucket.com/albums/y23...moved/0br3.jpg
step 4 pull the shroud back to expose the inside of the bumber cover.
http://i6.photobucket.com/albums/y23...moved/0br4.jpg
Step 5 remove the 7mm bolt in the corner of the bumper cover connecting it to the fender. also remove the 2 larger push rivets you see in the same area. (second push rivet is behind metal piece to the right in picture)
http://i6.photobucket.com/albums/y23...moved/0br5.jpg
this is what the larger push rivets look like.
http://i6.photobucket.com/albums/y23...moved/0br6.jpg
repeat steps 1-5 on the other side.
step 6 romove the air intake upper piece by twisting the two plastic hand screws and remove.
http://i6.photobucket.com/albums/y23...moved/0br7.jpg
step 7 remove the 2 10mm bolts on the corners of the bumper cover were it meets the fenders under the hood(already removed in picture 1). and also remove the 5 plastic push rivets.
http://i6.photobucket.com/albums/y23...moved/0br8.jpg
http://i6.photobucket.com/albums/y23...moved/0br9.jpg
http://i6.photobucket.com/albums/y23...oved/0br10.jpg
http://i6.photobucket.com/albums/y23...oved/0br11.jpg
http://i6.photobucket.com/albums/y23...oved/0br12.jpg
step 8 underneith there is a clip that holds the bumper cover to the chasis. there should be 2 (mine only had one, yeah those cheap.... :mad: )
http://i6.photobucket.com/albums/y23...oved/0br13.jpg
step 9 pull upward on the top part of the bumper cover near the headlight with one hand and pull outward on the corner below the fender at the same time with the other. the bumper will slide forward. only pull it out a few inches at first and then twist the turn signal sockets out of the housings before removing the bumper completely.
http://i6.photobucket.com/albums/y23...oved/0br14.jpg
a view with no bumper cover.... :wow: p.s the wires hanging are for my aftermarket fog lights.
http://i6.photobucket.com/albums/y23...oved/0br15.jpg
Elt31987 03-26-2010 09:41 AM
Perfect, ill post up pics of the lights after i get it installed. Prolly wont be for like another week
Gramps 03-26-2010 12:06 PM
Originally Posted by schoat333 (Post 9161971)
Here is a how to on removing the front bumper cover. (Gramps, feel free to move this to a how-to thread if you'd like.)
I put a link in the Quick Links sticky. Thanks for the "How To". :thumbsup:
I'll add that some of those "push pins" come out pretty easily if you use a couple of small "electronics size" screw drivers to pry the inner head up. Then the panel remover will pop them right out.
Tony1911 03-29-2010 02:07 AM
An anti-seize spray may also come in handy when removing push rivets. The little buggers can be stubborn sometimes, especially if they have dirt in them.
GNaqua 04-23-2010 11:57 AM
Originally Posted by Elt31987 (Post 9161761)
Hey, i usually spend most of my time in the KK section but on my Patriot MK im going to be installing an hid headlight kits. Im sure ill figure it out since i ripped my Libertys grill and lights out but anyone have a writeup or pictures of the front grill and hid kits removal? Thanks
Great set of pictures schoat333, thanks! :tea:
miketmx 04-23-2010 01:13 PM
The parking light lens on the driver's side of our Patriot has a rock chip crack and condensation forms inside the parking light. I hope that I don't have to remove everything just to replace that parking light lens ?? Does it come off with just a flat screw driver applied to the side ??
Gramps 05-02-2010 11:56 AM
Sorry Mike! I missed this earlier. http://www.jeepforum.com/forum/f98/c...lenses-718996/
miketmx 05-02-2010 06:15 PM
Thanks Bob. I suppose that the lens on a Patriot is held on by 3 screws just like the Compass but even if it is different, I will still have to remove the wiring connector and bulb according to the writeup. Our old Dodge Caravan had a sliding panel in the wheel well for access to the turn signal bulb but even then it was handier to remove the wheel for starters.
Dougget 07-03-2012 07:28 AM
schoat333,
Great write up. I followed it to the letter and had an easy time of removing my grill/bumper. I too only had one clip on the bottom. Really? what do those things cost, maybe $0.20 - $0.30... Oh well.
While my bumper cover was off, I installed an additional horn, three LED marker lights, and a set of driving lights (similar to the "Pilot" lights that have also been written up).
It all went back together well too. Now I just need to finish off the electrical. My lower dash is in pieces now as I look for a good place to put a couple of switches :)
Thanks again for taking the time to document the process.
Doug
bjlo4life 01-09-2016 03:39 PM
hey guys i have a question about a part # i have an 08 patriot and i need the little round metal "push type" lock washers that physically hold the black grill insert onto the front bumper cover. I broke just about every one of them a few years ago and now i need to replace them. any info will help me out. I looked at an exploded view on chryslers website but can't pinpoint which one it is. thanks everyone
The time now is 09:14 AM.
