Rear speed sensor location ? - JeepForum.com
post #1 of 9 Old 08-20-2011, 12:08 PM Thread Starter
Z3R0
1986 XJ Cherokee
A friend of mine has a 08 Patriot that has a c102b code. I looked it up and it says that both the rear speed sensors need to be replaced. The dealer wants about $400 for both parts and labor which I think is a bit too high. I was wondering if anyone could point out where these sensors are located so I can replace them myself. Thanks !
Z3R0 is offline
post #2 of 9 Old 08-20-2011, 01:23 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Front Wheel Drive or All Wheel Drive?
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 9 Old 08-20-2011, 01:36 PM Thread Starter
Z3R0
1986 XJ Cherokee
Idk why but in the service center papers it says it's a RWD. :S All I know it's a 2008 Patriot A/T 2.4l. It's not the limited model.
Z3R0 is offline
post #4 of 9 Old 08-20-2011, 04:04 PM Thread Starter
Z3R0
1986 XJ Cherokee
Here's the receipt from the first time it happened and was covered under warranty:
Basically what it says is that both rear speed sensors were found to have an open circuit and that they were replaced.
Z3R0 is offline
post #5 of 9 Old 08-20-2011, 04:18 PM Thread Starter
Z3R0
1986 XJ Cherokee
It's the FWD model. I searched the part numbers so if anyone could tell me where the sensors are they would be of great help.
Z3R0 is offline
post #6 of 9 Old 08-20-2011, 05:13 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
FRONT-WHEEL-DRIVE
REAR SPEED SENSORS
NOTE: Before proceeding, Warning for asbestos dust.
Fig 1
1. Remove the cargo floor cover.
2. Remove the rear floor pan silencer (1).
Fig 2
3. If equipped, remove the nuts mounting the satellite receiver (1) or amplifier (2) to rear floor pan. Move the component aside to allow access to the wheel speed sensor wiring connector through the opening in bottom of the quarter trim panel.
Fig3
4. Through the opening in the bottom of the quarter trim panel, disconnect the wheel speed sensor cable connector (2) at the body wiring harness connector (3).
5. Raise and support the vehicle.
Fig 4
6. Remove the wheel mounting nuts (3), then the rear tire and wheel assembly (1).
Fig 5
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #7 of 9 Old 08-20-2011, 05:14 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
7. Remove the grommet (2) from the hole in the body (1) and pull the wheel speed sensor cable out through the hole.
8. Remove the speed sensor cable routing clip (3) from the outside frame rail (4).
Fig 6
9. Remove the screw (1) fastening the cable routing clamp (3) to the rear suspension crossmember (4).
Fig 7
10. Remove the speed sensor cable routing clip (1) from the trailing link (2).
11. Remove the screw (4) fastening the cable routing clamp to the trailing link.
Fig 8
12. Remove the screw (1) fastening the wheel speed sensor head (3) in the rear of the hub and bearing (2). Remove the sensor from the vehicle.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #8 of 9 Old 08-20-2011, 05:22 PM Thread Starter
Z3R0
1986 XJ Cherokee
Thank you so much. I really appreciate your help. Now changing this will be a piece of cake.
Z3R0 is offline
post #9 of 9 Old 08-20-2011, 11:34 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Glad to help. Good luck!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
Location Blower Motor Resistor PoconoBill Jeep Compass & Patriot Forum 4 01-02-2016 06:56 PM
Boston Audio Amplifier Location spencernj Jeep Compass & Patriot Forum 1 05-12-2010 12:25 PM
Location of Radiator Drain Plug ssapmoc Jeep Compass & Patriot Forum 3 03-14-2010 03:00 PM
Location of engine block heater of Patriot 08 Pravsta Jeep Compass & Patriot Forum 1 01-07-2009 11:11 AM
Tempearture sensor location Trek620 Jeep Compass & Patriot Forum 5 11-22-2008 06:07 AM
