Rear Camera Systems Though Navigation - JeepForum.com
post #1 of 2 Old 09-29-2013, 03:06 PM Thread Starter
Biloxinative
2013 MK Patriot
Rear camera system though navigation
I have a 2013 patriot, that did not come with a rear camera back up system. Anyone know if there is one that can be installed though the navigation screen? I do not want to purchase one that attached to the rear license plate with the small LED screen to mount.. Thanks
Biloxinative is offline
post #2 of 2 Old 09-29-2013, 05:59 PM
NHPATRIOT
2014 KL Cherokee
As long as you have a touch screen radio like the 430 you can add a BUC. You need the camera and harness to hook it to the radio( special plug )and then the dealer has to flash the vehicle to activate it if you go MOPAR/OEM hookup. You can also get a LockPick harness that eliminates the dealer flash and lets you use any aftermarket camera of choice with a RCA type jack.
The MOPAR BUC kit specifically for a Patriot uses the rearview mirror( replaces it ). You could modify a kit for another vehicle to work as well if you wanted it to run through the head unit.
2014 Jeep Cherokee
Latitude
3.2L Pentastar V6
Active Drive I
NHPATRIOT is offline
