Rear brake pad change line removal necessary? - JeepForum.com
post #1 of 3 Old 12-19-2013, 02:54 AM Thread Starter
eshew
I'm running into an issue when trying to remove the top rear brake caliper bolt on a 2008 Jeep Compass. The brake line going into the caliper is in the way when trying to back out the top bolt. I have tried in vain to wiggle the bolt past the bottom brass fitting in the line but still can't get the bolt out.
Any suggestions would be welcome. If it comes down to having to remove the line what should I do to minimize brake fluid loss? Should I clamp the line or let it run & bleed it after? Or both?
When bleeding, as it may be a one man job, does anyone recommend getting a set of speed bleeders?
Thanks in advance!
Eric
eshew is offline
post #2 of 3 Old 12-19-2013, 12:37 PM Thread Starter
eshew
OK. A 2 minute Google search shows a YouTube video where the top bolt is loosened and the bottom caliper bolt is removed allowing the caliper to be rotated and the pads removed...should have thought of that.... Brilliant!
eshew is offline
post #3 of 3 Old 12-31-2013, 12:26 AM Thread Starter
eshew
Just a final update:
Rear pads went in fine, and pretty darn easy. Didn't even need to clamp the piston back in, just my manly hands.
The compass had a nasty habit of squealing the rear brakes when cold and reversing down the driveway. It really made some noise & vibration. Sucked.
I went with some Napa Adaptive One pads. The brakes are now silent & work great hot or cold.
eshew is offline
