rbz radio - JeepForum.com
post #1 of 11 Old 02-26-2013, 04:37 PM Thread Starter
Lehman26
2012 MK Compass
rbz radio
Found one for sale says it came out of a 2010 charger. Anyone know if this will work?
Lehman26 is offline
post #2 of 11 Old 02-26-2013, 04:41 PM Thread Starter
Lehman26
2012 MK Compass
Model/serial number on back is P05064959AF
Lehman26 is offline
post #3 of 11 Old 02-26-2013, 04:59 PM Thread Starter
Lehman26
2012 MK Compass
Also if it would work after installing does it require trip to dealer to activate?
Lehman26 is offline
post #4 of 11 Old 02-26-2013, 05:25 PM Thread Starter
Lehman26
2012 MK Compass
Anyone would like to make purchase asap..need some help
Lehman26 is offline
post #5 of 11 Old 02-26-2013, 06:26 PM Thread Starter
Lehman26
2012 MK Compass
Ok lol, i just bought it hope its right couldn't pass it up for $250..bought it 20 minutes after it was listed on ebay
Lehman26 is offline
post #6 of 11 Old 02-27-2013, 04:29 PM
NHPATRIOT
2014 KL Cherokee
What matters the most on these newer Chrysler brand vehicles is whether or not you have a high speed or low speed CANBUS system. You can't interchange them. So you need to know which version of the RBZ you got; high or low speed. You also need to know which CANBUS speed your vehicle needs and you need to get the correct one for it.
This is the Compass/Patriot forum but it says Liberty under your username? What is your vehicle? The Compass and Patriot use a low speed CANBUS system. The Liberty uses a High Speed CANBUS system. The 2010 Charger uses a low speed CANBUS so it would work in a Patriot or Compass but it won't work if you have a Liberty.
If you get the correct CANBUS speed model for your vehicle it is basically plug and play. If you add a backup camera you will need a dealer flash to activate it. UConnect will work as long as you get the required harnesses and modules( may require dealer flash ). The startup logo should swap over to Jeep after a few start cycles but if not the dealer can get it to swap with a scan tool
2014 Jeep Cherokee
Latitude
3.2L Pentastar V6
Active Drive I
NHPATRIOT is offline
post #7 of 11 Old 02-27-2013, 04:35 PM Thread Starter
Lehman26
2012 MK Compass
I purchased a low speed bus for my 2012 compass
Lehman26 is offline
post #8 of 11 Old 02-27-2013, 04:37 PM Thread Starter
Lehman26
2012 MK Compass
Thanks for the info glad to find out i bought the right unit...and also was wondering about the logo to..so after a few cycles it will change to jeep?
Lehman26 is offline
post #9 of 11 Old 02-28-2013, 06:30 AM
NHPATRIOT
2014 KL Cherokee
"USUALLY!" Not always however. Some of them are stubborn and the dealer has to hook it up to the scan tool and associate the head unit with the vin for it to happen.
2014 Jeep Cherokee
Latitude
3.2L Pentastar V6
Active Drive I
post #10 of 11 Old 02-28-2013, 06:32 AM Thread Starter
Lehman26
2012 MK Compass
Ok thanks!
Lehman26 is offline
post #11 of 11 Old 03-01-2013, 06:00 PM Thread Starter
Lehman26
2012 MK Compass
Installed today..works perfect no dealer visit needed. Just hoping the logo resets to jeep logo.
Lehman26 is offline
