Rattle in front steering over bumps - JeepForum.com
post #1 of 7 Old 03-01-2009, 08:41 AM Thread Starter
webdog
1990 XJ Cherokee
I was wondering if anyone has had any rattle in there compass up front when going over rough parts of road?
My friends does and I am just trying to diagnose where it is coming from, to me it kind of sounds like it is coming from the upper strut bearing or bushing up there.
Any other ideas?
webdog is offline
post #2 of 7 Old 03-01-2009, 10:00 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Things to check for tightness:
The 3 nuts on top of each of the strut towers. Pop the hood and they're back in the corners, easy to get at.
Sway bar links connected to the strut housing. (more of a "clunk". I left one loose )
Tie rod ends and rack and pinon (the factory left some of there loose it appears), also causes the wobblies.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 7 Old 03-02-2009, 07:49 PM Thread Starter
webdog
1990 XJ Cherokee
The driver side tie rod was lose the tire had about 1/4" of play when lifted off the ground and i was unable to tighten it anymore without totally rounding the nut so we took it to the dealer and they replaced the tie rod end under warrantee, now no more clunk...
Its always fun to go to a dealer / shop and tell them what to look for..
webdog is offline
post #4 of 7 Old 03-11-2009, 07:30 AM
penguinwise
Anybody know how much these bolts should all be torqued? Naturally I am already out of warranty when I get a clunk like squeak sound when I hit bumps. Its probably the tie rod, but I want to make sure everything is torqued right first. Thanks!
penguinwise is offline
post #5 of 7 Old 09-23-2009, 09:18 AM
penguinwise
Changed the tie rod ends and my clunk in the front is gone. I am still getting a squeak from the rear strut towers. Anyone else have this problem?
post #6 of 7 Old 09-23-2009, 11:56 AM
CanadianSkin
Had the same problem, with the same fix. Tie rods.
CanadianSkin is offline
post #7 of 7 Old 09-25-2009, 09:29 AM
howdy246
2008 MK Compass
Just had the tie rod ends replaced also. No problem getting them done under warranty.
howdy246 is offline
Antilock brakes engage when i hit bumps/potholes eviladam Jeep Compass & Patriot Forum 3 03-04-2009 10:08 PM
Steering Wheel Audio Controls davep Jeep Compass & Patriot Forum 26 04-21-2008 05:15 PM
2007 compass steering jpi54 Jeep Compass & Patriot Forum 6 01-01-2008 07:22 AM
Rattle Icekicker Jeep Compass & Patriot Forum 11 02-09-2007 03:40 PM
Rattle coming from driver's side door phil8400 Jeep Compass & Patriot Forum 1 10-28-2006 06:50 AM
