PTU and RDA fluid change - Page 3 - JeepForum.com
post #31 of 55 Old 10-27-2011, 08:47 AM
bigkat91
2011 MK Compass
I have emailed jeep before and they just quoted the manual.
2011 Compass 120K miles
RRO Lift
bigkat91 is offline
post #32 of 55 Old 10-27-2011, 09:59 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Here'a reply that I pulled on the 'net to the same issue.
You can definitely use synthetic in your rear diff and PTU. I worked for Chrysler for 5 years as a tech and also have run synthetics in my Patriot since I bought it 3 years ago and no issues. If you want to stick with MOPAR you can run their 75W-140 synthetic in your PTU and rear diff. The factory non synthetic 80W-90 is not that great and I have seen PTU's fail with this oil. The best place for synthetics is Amsoil.com. You just enter your vehicle and they will tell you what is available for the Patriot.
emailing or calling customer service at CDJ all you will get is 'see your owners manual'.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #33 of 55 Old 10-27-2011, 03:11 PM
NHPATRIOT
2014 KL Cherokee
I sometimes wonder if these people answering e-mails for car mfg's actually know how to read and if they have an education higher than 1st grade?
Their reply was to go to the dealer and they will tell me the correct part # to get. COME ON! I told them I wanted to use synthetic not the OE 80W90.
All the dealer will do is say the owner's manual says use 80W90. That is not an answer to my question.
OY!
2014 Jeep Cherokee
Latitude
3.2L Pentastar V6
Active Drive I
NHPATRIOT is offline
post #34 of 55 Old 10-27-2011, 08:38 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
When you call or email Customer Service you don't talk to engineers, they are really just ordinary people on the other end that will look up VIN numbers and tell you if there is a recall or something like that. The same thing as the salesmen don't know much ether, IRSmart is one of the few exceptions. That's why forums have become so popular, you're more apt to find the answers you need.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #35 of 55 Old 10-28-2011, 05:09 AM
NHPATRIOT
2014 KL Cherokee
I agree with you BUT instead of answering questions that they don't have a clue about forward it to an engineer or something to get the answer. Common sense.
2014 Jeep Cherokee
Latitude
3.2L Pentastar V6
Active Drive I
post #36 of 55 Old 10-28-2011, 01:51 PM
FujativeOCR
2011 MK Patriot
Im sure the last thing manufacturers want is a paper trail leading to them telling you you could do this or that. That will come back to bite them in the butt in court someday. (gotta love lawsuits). The easiest and safest thing for them to tell you to do is follow the directions.
FujativeOCR is offline
post #37 of 55 Old 10-28-2011, 02:13 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
It's the old CYA or get sued, you're right! I even try to do that with caveats on in JF. I don't know if suing the forum or me would hold in court but I don't want to find out the hard way. If there is addition info it's either from personal experience or I tell you where the info came from, either way you'll know. I miss the 'good old days' when life was simple and ppl weren't so sue happy.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #38 of 55 Old 10-28-2011, 07:04 PM
bigkat91
2011 MK Compass
Me too Gramps
RRO Lift
bigkat91 is offline
post #39 of 55 Old 10-28-2011, 11:47 PM
bigkat91
2011 MK Compass
I went to change the gear oil this evening (wanting to get all the break material in the oil out), but my drain plug takes a 10mm hex and stopped the whole process...
RRO Lift
bigkat91 is offline
post #40 of 55 Old 10-29-2011, 08:35 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Yup, we need to go metric every inch of the way. Taking out your back seat will take a T-50 Torx if you ever need to do that.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #41 of 55 Old 11-04-2011, 01:35 PM
jeepjig1
Took the jeep into the dealership because the malfunction indicator light came on. I was also planning to have the CVT serviced and see if they could find this squeak. They couldn't find where or what was causing the squeak (bird chirp). It also seems not to be as common now that the weather is getting colder. I mainly notice it when turning off the engine. Maybe something got on the belt that’s causing it. Who knows….
The malfunction light was on because the computer needed an update and reset.
The dealership actually recommended I don’t change the CVT oil or get it serviced because it is a sealed unit, difficult to get all the oil out, and refill to the correct level. Ok.
jeepjig1 is offline
post #42 of 55 Old 11-04-2011, 08:20 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I have an annoying 'chirp' that comes the inner rear hatch panel that pops loose.
During the month I worked at a dealership the main mechanic, that I trusted, said the same thing about the CVT fluid.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #43 of 55 Old 11-15-2011, 01:49 AM
misfitJason
I find this very usefull thanks
misfitJason is offline
post #44 of 55 Old 05-14-2012, 01:26 PM
howdy246
2008 MK Compass
Changed my PTU and rear drive unit. Each only had about 1/2 a quart in them and took about the same amount to refill. I needed a 10mm hex socket, 15/16 wrench and a 17mm socket to change both fluids. Don't forget to clean off the magnets on the lower drain plugs for both units.
howdy246 is offline
post #45 of 55 Old 05-15-2012, 09:02 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Thx Howdy for the tools needed and needed quantities info!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
compass , patriot , power transfer unit , ptu , rda , rear drive axle
Oil change indicator Trek620 Jeep Compass & Patriot Forum 25 11-24-2009 02:14 PM
Oil Change pshingle Jeep Compass & Patriot Forum 13 07-02-2009 12:15 PM
Oil change question Skipsjh Jeep Compass & Patriot Forum 8 06-03-2009 03:58 AM
Should I be worried about oil change indicator? udmover Jeep Compass & Patriot Forum 3 09-03-2008 07:06 AM
How to change out the radio?? lynnk Jeep Compass & Patriot Forum 10 11-01-2006 05:50 PM
