Program Patriot Key - JeepForum.com
post #1 of 12 Old 01-10-2013, 09:07 PM Thread Starter
ruholm
2008 WK
Program Patriot Key
My sister in law just bought a patriot and it only had one key. If she buys another one do the have to take it to the dealer to get programmed?
OME MD lift kit 245/70/17 Revo's2, 5/8 shackles
ruholm is offline
post #2 of 12 Old 01-11-2013, 04:24 AM
FourPointZero
2013 MK Patriot
According to the Internet:
1. Insert the first of the two valid keys into the Jeep Patriot's ignition and start the engine. Leave the engine running for five to 10 seconds, then turn the engine off and remove the first key.
(You can skip step 2)
2. Within 15 seconds of removing the first key, insert the second of the two valid keys into the ignition and start the engine. You will hear a chime after 10 seconds, then the Vehicle Security Light will begin to blink. Turn the engine off and remove the second key.
3. Insert the key you would like to program into the ignition and start the engine--this must be performed within 60 seconds of removing the valid key. After 10 seconds, you will hear a chime and the Vehicle Security Light will stop blinking. The Security Light will return for three seconds, then turn off, indicating the programming was successful. Repeat steps 1 through 3 for each additional key you would like to program.
Hopefully this works for you.
FourPointZero is offline
post #3 of 12 Old 01-11-2013, 04:54 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
One key won't do it, two are required. After you have the second key then you can make a spare and put it in a safe place.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #4 of 12 Old 01-11-2013, 05:05 AM
FourPointZero
2013 MK Patriot
So he'll need to take it into the dealer for programming?
Thanks
post #5 of 12 Old 01-11-2013, 07:08 AM
IRSmart
2015 KL Cherokee
Thanks
yes
IRSmart is offline
post #6 of 12 Old 01-11-2013, 07:24 AM Thread Starter
ruholm
2008 WK
Thank you all for the help.
ruholm is offline
post #7 of 12 Old 01-11-2013, 01:34 PM
FujativeOCR
2011 MK Patriot
How much is a spare key without programming? Might behoove us to buy a spare and program it for free while we still have the 2 originals.
FujativeOCR is offline
post #8 of 12 Old 01-11-2013, 03:07 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I'n not trying to side steep the dealership but I found an uncut, unprogrammed key on eBay. Mine was the full security key with the lock/unlock buttons and all and not one with just a chip. If it's just a key with a chip only then even ACE hardware has some of those and they can cut them too.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #9 of 12 Old 01-13-2013, 12:00 PM
Vetteman76
2012 MK Patriot
Bought mine off Ebay for $13.99. Just under $10 to cut and programmed it myself. Apparently you can do the programming 6 times.
Dave
Vetteman76 is offline
post #10 of 12 Old 02-20-2013, 07:16 PM
aquaman67
Were you able to program the full security key as described above?
aquaman67 is offline
post #11 of 12 Old 02-21-2013, 07:24 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Yup, it worked fine, no problems at all. Just make sure it's uncut and not programmed. I 'think' it was about $60 for the full remote key, not just the 'chip' . That was back in '06 so prices could have changed.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #12 of 12 Old 02-21-2013, 02:53 PM
aquaman67
Thanks to your input I'm going to give this a try.
I found one three button remote key and two plain keys, all new, uncut and unprogrammed for $48 with a 90 guarantee on the very large auction site.
I'll let you how it works out. Wish me luck!
UPDATE:
It worked! Thanks. Saved me $140.
