Power outlets - JeepForum.com
post #1 of 7 Old 06-03-2007, 05:05 PM Thread Starter
danbo
Power outlets
Just out of curiousity, do any of the power outlets stay on when the Patriot is off. I have gotten spoiled with my Jeep Grand Cherokee and being able to charge my cell phone or mp3 player while I am not in the car. Comes in pretty handy when you forget to do it at home!
danbo is offline
post #2 of 7 Old 06-03-2007, 07:03 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
They all run threw the ignition circuitry so that you don't run down the battery.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 7 Old 06-03-2007, 07:28 PM Thread Starter
danbo
Thanks, thats too bad though. I've been doing it for 4 years and never ran down my battery. Guess I'll have to figure a way around it.
danbo is offline
post #4 of 7 Old 06-07-2007, 04:57 AM
madrabbitt
madrabbitt's Avatar
install an outlet of your own. Its not that hard to do.
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
post #5 of 7 Old 06-07-2007, 07:03 AM
eighteenwheeler
Go to walmart or something like that. For 8 or 9 bucks they have a Truck bed outlet kit. You can connect this directly to the battery, or to another always on source. If your only going to charge your phone and stuff, you can splice it right into the radio harness. If your going to be demanding, or if you "want to do it right", connect it to the battery or even better yet, the fuse box. Walmart also has the fuse holders and fuses for like 2 bucks. If you connect it to the fuse box or battery, be sure to use a fuse- 5, 10, or 15 amp are common.
If you dispise walmart as much as I do, these parts area available elsewhere, such as Autozone and napa.
eighteenwheeler is offline
post #6 of 7 Old 06-07-2007, 07:10 AM
madrabbitt
madrabbitt's Avatar
last line amused me.
i ONLY go to walmart between 1am and 5am unless its an emergency.
post #7 of 7 Old 06-07-2007, 08:05 AM
eighteenwheeler
Actually, I just got another good idea for you.
open up the fuse box. Now open up the fuse box itself, not just the cover.
Remove or cut the Yellow wire going to cavities 37 (Inverter) and 11
Run a wire from the + that is running into the fuse box to the cativies 37 (Inverter) and 11
You could also use the wire at cavity 29 in place of the +.
be sure to remove or tape up the yellow wire so it doesnt short. If you don't remove the yellow wire you will short the ignition system.
my research shows that this wire is yellow, but it might now be- it will be coming from a yellow wire at some point however. (might be distributed with different colors- I don't know)
If someone knows any flaws/more info with this, please post up.
I'm not responsible if you mess something up <- Legal Disclaimer
01 Jeep TJ
Plus 9 other less durable vehicles from Italy, Germany, and 'Merica
Power locks and off-road lights. cactus_jack Jeep Compass & Patriot Forum 8 12-31-2009 11:22 AM
2008 Compass power windows. horsepower Jeep Compass & Patriot Forum 9 08-25-2009 03:45 PM
Power bump drive train Bae146jet Jeep Compass & Patriot Forum 8 08-21-2009 06:30 AM
loss of power? CharBroiled Jeep Compass & Patriot Forum 13 03-29-2008 07:27 PM
Want Power Options dolanmx305 Jeep Compass & Patriot Forum 7 03-16-2008 06:35 PM
