Please Help - Trailer Harness Problem Compass - JeepForum.com
post #1 of 8 Old 04-03-2010, 10:26 PM Thread Starter
gthem
I have a 2007 Compass and have had the towing harness that came with the vehicle when I purchased it. I just installed it last week and I have nothing. My vehicle lights work, but I am not getting any power to the wiring harness plug. I have a plug that is in the diagram that plugs into a plug on the left side, but there's nothing to plug it into on the other end. I have seen other posts talking about a wire that has to be run from the back of the vehicle to the front which seems absurd to have to this. The part number on the cable is P05084123AB but I can't seem to find anything about it. I have seen a bulletin (TSB 06049) that states "missing harness or incorrect wiring". I went to the dealer this morning and he doesn't show anything in the "Chrysler" system about a bulleting. I am really frustrated and want to take my boat out this week and the lights will not work. Any help would be great.
Thanks,
Greg
gthem is offline
post #2 of 8 Old 04-04-2010, 05:40 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The instructions start on post 19 over here http://www.jeepforum.com/forum/f98/f...29/index2.html with the pdf instructions here
http://site.justforjeeps.com/guide/82209280AC.pdf step 24A/B shows the wire that I'm familiar with that needs to be cut if it's an '08.
That part number that you list does not show for the harness, maybe it's a number for a relay? Also the TSB doesn't have the right kind of number sequence. It should be xx-xxx-xx with or with out the "-".
I am confused by what you're saying here: "I have a plug that is in the diagram that plugs into a plug on the left side, but there's nothing to plug it into on the other end."
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 8 Old 04-04-2010, 05:52 AM Thread Starter
gthem
Compasss Trailer Tow Issue
Thanks for the reply, but my harness didn't come with any wiring to run all the way to the front of the vehicle. If you search for TSB 06049 the bulletin shows up in a lot of places, like Edmunds.com recalls etc. The bulletin states that it is either "Incorrect wiring or a missing harness". This really is a plug and play operation. Thanks.
Greg
gthem is offline
post #4 of 8 Old 04-04-2010, 06:18 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
According to my search "The problem with the NHTSA Technical Service Bulletin (TSB) information is it gives you absolutely nothing to go on, except for a title. Even the TSB number is essentially meaningless, because it's assigned by the NHTSA after the manufacturer as already assigned the TSB their own number" but I can not find the factory TSB on it Complete list of all Caliber Technical Service Bulletins - Dodge Caliber Forums
If you have the wrong harness then you need to get the right one. It looks like the factory gave you the wrong harness the best that I can tell. If you try and "make shift" the wrong harness you can damage the TIPM.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 8 Old 04-04-2010, 06:30 AM Thread Starter
gthem
Trailer Tow Issue
Thanks for the reply. I pulled out the instruction manual. The number on the instruction manual is 68019154AA dated 5/30/06. There are 4 relays. In the diagram, the 4 relays are horizontal, do they have to be for them to work properly? I wouldn't think so, but was wondering. Also, there is no mention of attaching a ground wire anywhere. It must be in the harness I guess.
Thanks,
Greg
gthem is offline
post #6 of 8 Old 04-04-2010, 06:40 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I believe the relays are electronic not mechanical and can be mounted in any position. Mine are curled up in the "well" on the drivers side in the boot. The only ground on mine attaches directly to the battery, as does the power lead.
Those are some very early instructions, the first Compass' sold were 07/06 and mine was build in 06/06 but I got the harness later and not when I bought it.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #7 of 8 Old 04-04-2010, 05:01 PM
wesleyd
2009 MK Compass
Thanks,
Greg
I think that mopar has two different harnesses. The one i bought didn't go to the tail lights at all. The plug went out the back through a hole drilled in the floor under the spare and the power wires went all the way to the battery and main control module. The relays and such are all bundled together and tucked away under the spare area.
wesleyd is offline
post #8 of 8 Old 11-12-2011, 01:20 PM
ogbo
This was a tough one to find on a Caliber as well... the connection this fellow was looking for was buried inside the left rear quarter panel, BEHIND the rubber seal! go figure... thought I'd reply to this `old' post, just in case someone else has the same problem.
ogbo is offline
compass , electrical , patriot , relays , trailer harness
HID kit problem on MK's Laloggia Jeep Compass & Patriot Forum 78 10-22-2011 07:50 AM
Factory Trailer Wiring Harness Installation coachwillb Jeep Compass & Patriot Forum 20 04-24-2009 09:41 AM
07 Jeep compass starting problem anthonylee Jeep Compass & Patriot Forum 4 04-07-2009 04:24 PM
compass problem umopp Jeep Compass & Patriot Forum 1 12-22-2008 08:58 AM
07 Compass Stalling Problem ups4 Jeep Compass & Patriot Forum 5 11-17-2007 05:18 PM
