Pics of Camshaft 2007-2009 Patriot/Compass? - JeepForum.com
post #1 of 2 Old 06-25-2012, 08:48 AM Thread Starter
HeavyOnTheSkinn
Hi i'm looking for a picture of the camshaft from a Compass or Patriot 2007-2009. Can anyone post one or give me a better idea where/how to search for one? I'm trying to get a look at the end with the camshaft position sensor target. I've tried searching myself a little but couldnt find what i was looking for specifically. Thanks for any information you can provide.
HeavyOnTheSkinn is offline
post #2 of 2 Old 06-26-2012, 09:20 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Let me know if this helps.
Camshaft Position Sensors.
The timing drive system consists of the following:
• Timing Chain (2)
• Camshaft Sprockets (1,3)
• Crankshaft Sprocket
• Right Timing Chain Guide (Moveable) (6)
• Left Timing Chain Guide (Fixed) (4)
• Timing Chain Tensioner (5)
The camshaft sprockets are attached to the cam phasers which are attached to the front of the camshafts and is used with the timing chain and crankshaft sprocket to turn the camshafts. The camshaft position sensors target is part of the camshafts and is used with the camshaft position sensors to provide the PCM with valvetrain position information.
The timing chain tensioner is installed in the right side of the engine block. Using engine oil pressure, the tensioner applies constant pressure to the right side (movable) timing chain guide, which in turn applies pressure to the timing chain. Also as the tensioner extends, it rachet locks in position to provide constant timing chain tension.
See pic 1
Align the timing marks (1) on the intake cam sprocket with the painted chain link.
Verify that the timing marks (1) are aligned on both camshafts and that the timing marks (3) are parallel with the cylinder head.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
compass vs patriot. aroundincircles Jeep Compass & Patriot Forum 4 11-28-2011 01:19 PM
Compass and Patriot getting Sh*t on... armystrong68w Jeep Compass & Patriot Forum 27 03-10-2011 06:12 PM
compass vrs patriot mpg polock Jeep Compass & Patriot Forum 7 10-24-2009 03:47 PM
Hi, I bought a new 2007 Inferno Red Compass Limited 2 days ago, yes-NEW 2007- Beware Jeep Compass & Patriot Forum 5 04-20-2009 06:40 AM
Compass vs. Patriot Kev M Jeep Compass & Patriot Forum 118 03-05-2008 05:34 PM
