Permanent 4 WD on tarmac? - JeepForum.com
post #1 of 3 Old 07-08-2007, 04:31 AM Thread Starter
Red_Compass
I have a UK model of the Compass, it has "permanent" 4 wheel drive but I'm not sure of the advantages (if any) or indeed what problems it might cause by running in 4WD all the time. The manual doesn't say not to do it and there aren't any strange noises when driving on dry surfaces, but I wonder what others do or have been advised?
Thanks
2 Litre Turbo Diesel Jeep Compass Ltd
4 x 4 drive train, 6 speed manual
Red_Compass is offline
post #2 of 3 Old 07-08-2007, 05:54 AM
hunter44102
4x4
Red Compass - The 4x4 Compass and Patriots have a computer-controlled 'on-demand' four wheel drive. It is normally off and comes on as needed.
There is a long discussion at the following thread (at jeep patriot .com):
www.jeep patriot.com/forum/showthread.php?t=1971
remove spaces between jeep and patriot on the link above and plug into browser..
hunter44102 is offline
post #3 of 3 Old 07-08-2007, 07:23 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Thanks
Our best description of how the 4WD system works is here:
http://www.jeepforum.com/forum/f98/noobish-question-about-patriot-4wd-system-esp-system-423860/
In regards to your question about running in a constant 4WD mode I can't see where this would be a problem or a benefit on dry pavement. Early reports mentioned that the Euro versions would be programmed differently for the Euro market.
The statements made in the other forum such as: "the 4x4 lock only works to 10-15mph" I have not been able to verify other than as Jeep says the Lock Mode is "to master extra slippery conditions at low speed in deep snow. sand and loose gravel", it does not say that it turns off at higher speeds.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
