Patriot vs Liberty - JeepForum.com
post #1 of 3 Old 11-20-2011, 11:14 AM Thread Starter
aroundincircles
1989 XJ Cherokee
Patriot vs Liberty
I've been looking at my options. and which is better off road, a jeep liberty, or a patriot(trail rated)? Looking at the specs, the pat has a better ground clearance, and a departure angle. i know its smaller, and has less power, is that its off road weakness? i didn't see a package for the liberty that gives it better ground clearance.
aroundincircles is offline
post #2 of 3 Old 11-20-2011, 01:21 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The Libby has a real Hi/Lo transfer case, is better 'out of the box' for off-rodding and can be modified even more with lots of aftermarket goodies. On the other hand the mpg sucks.
No matter how much ground clearance you have you will always find something bigger that you want to go over. Skid plates are a better answer and many of the Liberty's have those.
Several of the Liberty folks stop in here and I'm sure they can give you much more details on them.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 3 Old 11-20-2011, 03:23 PM
Mike97ZJ
Liberty is going to be the much better choice offroad. It has an actual low range transfer case, and a solid rear axle which will give you more suspension travel/articulation in the rear.
Also, if you plan on modifying it, there's much more for the Libby.
Patriot/Compass isn't really designed for offroad. You can do it, but a Libby is set up much better for it. It seems to me the Pat is in the lineup to compete with the likes of the CRV, Rav4, etc. Being a Jeep though, it DOES have to have some kind of offroad ability, so in that class of vehicle it's tops. But really no comparison to something with a solid rear and low range.
Keep in mind they're also different classes of vehicle, so it depends on what your main priorities are. The Pat is going to get better mileage and probably ride/drive better on the street, and the Libby is more trucklike but a solid offroader and maybe has more cargo room/towing ability.
And the Pat has more ground clearance on paper, but less in the real world. They measure ground clearance from the lowest point on the vehicle, which is normally the differentials. Being that the Pat is independant suspension front and rear, there's good clearance under the diffs. The Lib has a solid rear axle, so the differential hangs down lower. However, common sense driving negates any disadvantage from this.
For clearance you really want to look at how much there is under the rockers and transfer case, those are the important places. Picture it like this - the way clearance is measured on the specs you've seen, you could put a 6" lift on the Libby, and as long as you left the stock tires on it, the clearance measurement wouldn't change. Now in the real world, in that scenario, which one do you think would REALLY have the most useable clearance, despite the specs?
Oh, and are you looking to buy new or used? If used, also look at the Grand Cherokee, it's also very capable offroad.
Mike97ZJ is offline
Liberty rims and tires on Patriot? mechetti Jeep Compass & Patriot Forum 3 10-06-2011 07:03 AM
"Upgrade" from Liberty to 2011 Patriot? paulmm Jeep Compass & Patriot Forum 3 04-21-2011 09:36 AM
Liberty or Patriot or ??? Standardbredwom Jeep Compass & Patriot Forum 8 04-01-2011 04:20 PM
'08 Liberty vs. Patriot mcd001 Jeep Compass & Patriot Forum 26 04-14-2008 11:32 AM
i thought the patriot was going to replace the liberty? orangez Jeep Compass & Patriot Forum 5 01-28-2007 06:36 PM
