Patriot Trail Rated Questions - JeepForum.com
post #1 of 2 Old 11-30-2007, 08:31 AM Thread Starter
goose1
I was wondering if anyone could shed some light on how Jeep builds the Patriot to be Trail Rated. More directly, I was hoping to figure out how they add the additional inch of ground clearance to the vehicle straight from the factory. Do they use longer shocks and springs or is it just spacer-like a RR kit? If they use the first, can I get that through the dealership or would I have to go to a justforjeeps.com or something like that?
I really like the Patty, but I was hoping to tweak it to the best stock look it can get. I should get the new wheels/tires for the Patty today or tomorrow. The dealership didn't have any 17s in the shop and are having to order them. Weird...
2006 Jeep Grand Cherokee Laredo (WK) 28E
4.7 V8, Quadra-Trac II, Black Exterior, Light Khaki Interior
Upgraded: Mopar Sport Utility Crossbars
2008 Jeep Patriot Sporkt (MK) 26E
2.4L, CVVTII, 2WD, Black Exterior, Dark Gray Interior
goose1 is offline
post #2 of 2 Old 11-30-2007, 09:20 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The first thing to do is look at the MK Parts Book. You can get it here at nearly,normals site: http://www.nearlynormal.biz/jeep/patriot_info.html Down load it and save it. Once you have it you can go through the front and rear suspension, transaxle and rear axle sections and you’ll find that the only major component differences are the following:
Transaxle, CVT2 vs CVT3 (2L)
Front half shafts – may be a different spline to match the transaxle (likely) or a different length (not likely).
Rear Axle Assembly – different gear ratio (likely) or different mounting (not likely).
Electronic Coupling
Clip for rear axle vent tube for FD II only (water fording).
Transmission Control Module.
Rear Lower Control Arm – has extra bracing. See pics 3rd post, last picture http://www.jeepforum.com/forum/f98/patriot-limited-fd-ii-test-drive-402333/
If you fully scroll down threw ALL of the pages just keep an eye on the BODY and TRANS headings looking for anything that is EXCLUSIVELY for BODY 74 (Patriot) and DAW (Cont.Var. w/Off-Rd Crawl Ratio Tran) and you’ll find what makes up the FD II package. What you will NOT find a difference in is springs, shocks, struts or any other suspension components including spacers. The codes such as SDC, SDE, SDF, ZFR, ZUR, ZFS etc. are different pieces for different engines, transmissions, FWD, A/C etc.
Having said all that and if you’ve made it this far the answer that you’re looking for is:
The FWD Patriot has 8.0’ gc
The FD I Patriot has 8.5” gc
The FD II Patriot has 9.0” gc because of a .7” taller tire = .35” more gc.
Now I do know my math, that’s only 8.85 gc
How about +.15” for marketing hype. Engineering tells them “about 1”, the first draft of the sales brochures drops the “about” and the final comes out with “a full 1” over the standard Patriot. Sounds like good PR work to me.
Figures don’t lie but I do expect to catch some flak on this. That’s why I had to put in all of the stuff from the parts manual.
Additional input is welcome!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
Some Questions - Considering Purchase of Compass/Patriot ScottRempel Jeep Compass & Patriot Forum 3 11-16-2008 10:37 AM
2009 Patriot questions boon4376 Jeep Compass & Patriot Forum 2 09-18-2008 08:03 AM
Patriot Questions Thelt Jeep Compass & Patriot Forum 3 08-30-2008 04:47 PM
getting patriot, can't decide color! (how is the patriot?) taseal Jeep Compass & Patriot Forum 20 02-09-2008 12:46 AM
Trail rated badge phil8400 Jeep Compass & Patriot Forum 24 12-24-2007 04:56 PM
