Patriot's Capability vs. (blank) - Page 2 - JeepForum.com
post #16 of 22 Old 09-02-2006, 11:46 AM Thread Starter
unclejjg
Here is a video of the new LR2.....skip ahead and you'll see it work thru some mud. Will the Patriot be able to handle this as easily? Will it handle more?
http://www.landroverusa.com/us/en/Ve...2/overview.htm
unclejjg is offline
post #17 of 22 Old 09-02-2006, 07:57 PM
JeepFreak91
dude its not even out yet so all you can do now is compare the specs. as soon is it gets out people can take it through mud and offroad and report back
JeepFreak91 is offline
post #18 of 22 Old 09-02-2006, 09:30 PM
MtnBikingAddict
LR2 is a replacement to the Freelander, let's compare that to a Patriot
2005 Freelander has independent suspension, 174hp 2.5L V6 (that's one small V6), and 7.3" of ground clearance.
Patriot has independant suspesnion, 172hp, and 9" of ground clearance.... Seems like a good fight.
FUTURE: 2007 Jeep Patriot Freedom Drive II Off-Road
CURRENT: 2006 Dodge RAM 1500 SLT, QuadCab SB, 4.7L Magnum V8, 5AT, 3.55, With a ton of Mopar goodies.
PAST JEEP(s): 2001 Jeep Grand Cherokee Laredo, Selec-Trac 4x4, 4AT, I6 4.0L, 3.73 (80,000 Miles)
MtnBikingAddict is offline
post #19 of 22 Old 09-02-2006, 11:48 PM
MtnBikingAddict
I got bored and made this, some of the vehicles that compare to the Patriot price wise.
2007 Jeep Patriot Sport Freedom Drive II
Drivetrain Type: Full-Time 4x4, Lockable Center Coupling (Part-Time 50/50 front/rear torque distribution), Low Range, Off-Road Brake Traction Control, Hill Decent Assist, Open Differentials (Assisted by BTC), 3 Mode ESP
Ground Clearance: 9"
Approach Angle: 29
Departure Angle: 33
Breakover Angle: 23
Engine: 2.4L I-4, DOHC, Dual VVT, 172hp, 165ft-lbs
Transmission: 2nd Generation CVT w/ Low Range
Low Range: Yes
Suspension: 4 wheel independent
Tires: 215/65-17
2007 Honda Element EX AWD
Drivetrain Type: Honda Real-Time 4WD: FWD w/ AWD assist when front wheels slip, upto 20% torque to the rear wheels (Mechanical system, uncontrollable), Open Differentials
Ground Clearance: 6.9"
Approach Angle: 23.9
Departure Angle: 21.3
Breakover Angle: Unkonwn
Engine: 2.4L I-4, DOHC, VTEC, 166hp, 161ft-lbs
Transmission: 5 Speed Manual or 5 Speed Automatic
Low Range: No
Tires: 215/70-16
2006 Suzuki Grand Vitara X-Sport 4WD
Drivetrain Type: Full Time 4-Mode 4WD, Low Range, Limited Slip Center Coupling, Open Differentials
Ground Clearance: 7.9"
Approach Angle: 29
Departure Angle: 27
Engine: 2.7L V6, DOHC,185hp, 184ft-lbs
Low Range: Yes
Tires: 225/70-16
2007 Toyota RAV4 Sport 4WD
Drivetrain Type: Electronic On-Demand 4WD, Hill Start Assist, Hill Decent Assist, Traction Control, Rear Limited Slip Optional
Ground Clearance: 7.5"
Approach Angle: 29
Departure Angle: 25
Engine: 2.4L I-4, VVT, DOHC, 166hp, 165ft-lbs or 3.5L V6, VVT, DOHC 269hp, 246ft-lbs
Transmission: 4 Speed Automatic (I-4) or 5 Speed Automatic (V6)
Low Range: No
Tires: 235/55-18
2006 Kia Sportage 4WD
Drivetrain Type: Electronic On-Demand 4WD, Open Differentials
Ground Clearance: 7.7"
Approach Angle: 29
Departure Angle: 28
Engine: 2.0L I-4, CVVT, DOHC, 140hp, 136ft-lbs or 2.7L V6, DOHC 173hp, 178ft-lbs
Transmission: 5 Speed Manual or 4 Speed Automatic (I-4) or 4 Speed Automatic (V6)
Low Range: No
Tires: 235/60-16
2005 Land Rover Freelander
Drivetrain Type: Full-Time AWD, Decent Control, Traction Control, Open Differentials
Ground Clearance: 7.3"
Approach Angle: 30
Departure Angle: 34
Engine: 2.5L V6, DOHC, 174hp, 177ft-lbs
Transmission: 5 Speed Shiftable Automatic
Low Range: No
Tires: 225/55-17
2007 Toyota Tacoma Regular Cab SR5 4x4
Drivetrain Type: RWD, Part-Time 4x4, 2 Speed Transfer Case, Open Rear Differential, Automatic Locking Front Hubs
Ground Clearance: 9.4"
Approach Angle: 35
Departure Angle: 26
Breakover Angle: 27
Engine: 2.7L I-4, VVT, DOHC, 159hp, 180ft-lbs
Low Range: Yes
Suspension: IFS w/ solid rear axel
Tires: 245/75-16
2007 Ford Escape XLS 4WD
Drivetrain Type: Full-Time 4WD, Open Differentials
Ground Clearance: 8.2"
Approach Angle: 20.8
Departure Angle: 28.1
Breakover Angle: 20.8
Engine: Duratec 2.3L I-4, 153hp, 152ft-lbs
Low Range: No
Tires: 225/75-15
2006 Hyundai Tuscon GLS 4WD
Drivetrain Type: FWD w/ Automatic 4WD, User Selectable Part-Time (50/50 front/rear torque distribution), Open Differentials
Approach Angle: 28
Departure Angle: 32
Breakover Angle: Unknown
Engine: 2.7L V6, 173hp, 178ft-lbs
Transmission: 4 Speed Shiftable Automatic
Low Range: No
Tires: 235/60-16
2006 Mazda Tribute S 4WD
Drivetrain Type: Full-time with electronic sensors determining center differential power distribution, Open Differentials
Ground Clearance: 8.4"
Approach Angle: 30
Departure Angle: 26
Breakover Angle: 20
Engine: 3.0L V6, DOHC, 200hp, 193ft-lbs
Low Range: No
Tires: 235/70-16
post #20 of 22 Old 09-03-2006, 07:06 PM
egalsim
Approach Angle: 29
Departure Angle: 33
Breakover Angle: 23
Low Range: Yes
Tires: 215/65-17
Low Range: No
Tires: 215/70-16
Approach Angle: 29
Departure Angle: 27
Low Range: Yes
Tires: 225/70-16
Approach Angle: 29
Departure Angle: 25
Low Range: No
Tires: 235/55-18
Approach Angle: 29
Departure Angle: 28
Low Range: No
Tires: 235/60-16
Approach Angle: 30
Departure Angle: 34
Low Range: No
Tires: 225/55-17
Approach Angle: 35
Departure Angle: 26
Breakover Angle: 27
Low Range: Yes
Tires: 245/75-16
Low Range: No
Tires: 225/75-15
Approach Angle: 28
Departure Angle: 32
Low Range: No
Tires: 235/60-16
Approach Angle: 30
Departure Angle: 26
Breakover Angle: 20
Low Range: No
Tires: 235/70-16
Of all of these listed, only the Toyota Tacoma is off road capable. The Tacoma, can also be easily upgraded suspension and driveline wise to tackle a Rubicon like trail.
egalsim is offline
post #21 of 22 Old 12-05-2006, 01:32 PM
offroader156
The Patriot is made to compete (on the market) in the compact SUV class. Such as the Toyota RAV4, Suzuki Grand Vitara, Kia Sportage, Honda CRV, etc. But comparing it offroad with anything but the Suzuki would be pointless.
offroader156 is offline
post #22 of 22 Old 12-06-2006, 08:02 PM
pdxbubba
2006 KJ Liberty
...that's for the regular cab. It can not haul 5 people (legally).
... ... ... Go Play Outside ... ... ...
pdxbubba is offline
How does the Patriot's off-road CVT w/crawl ratio compare to regular CVT II? eighteenwheeler Jeep Compass & Patriot Forum 14 04-07-2012 09:18 AM
Patriot's reliable?? diver110 Jeep Compass & Patriot Forum 18 10-20-2010 02:14 PM
