Patriot needs some help - JeepForum.com
post #1 of 4 Old 07-12-2011, 12:11 PM Thread Starter
firstresponder
"I have a throttle valve sticking and need it unstuck to pass emissions.
its a intake runner stuck open but all the jeep patriot forums say its a a flow actuator valve and the dealerships want to replace the whole manifold"
the above is a message sent to me by a friend. Her patriot apperently has this intake runner or what not stuck open. Now of course im sure the dealership wants to replace all that because they want her greenbacks. is there any info on this out there on what to do or what the real fix is?
maybe some need to know info also. it is the 4x4 4cyl 5speed. she just upgraded to the 17inch wheels and had the dealership flash the computer. the code the jeep is throwing is "error code P2004 -intake runner stuck open...." any clues?
firstresponder is offline
post #2 of 4 Old 07-12-2011, 07:22 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The P2004 code gives 16 different scenaros to check out. Assuming they checked the 15 electrical test and determined they were OK it comes down to this:
MANIFOLD FLOW VALVE
Turn the ignition off.
Using the wiring diagram/schematic as a guide, inspect the wiring and connectors between the Manifold Flow Valve and the Powertrain Control Module (PCM).
Look for any chafed, pierced, pinched, or partially broken wires.
Look for broken, bent, pushed out or corroded terminals.
Refer to any Technical Service Bulletins that may apply.
Remove the Manifold Flow Valve.
Inspect the return spring and the valve blade assembly for debris stuck in the path or for frozen/seized blades.
NOTE: Manifold Flow Valve over travel or under travel can cause this DTC to set.
NOTE: If the Manifold Flow Valve blades are seized in the intake manifold, the manifold will have to be replaced.
NOTE: If the Manifold Flow Valve is replaced, a non volatile memory reset must be performed to learn the new port flap adaptive values.
If they just read the code and didn't actually do any testing then it would take quite a while to post the info for you to do it.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 4 Old 07-14-2011, 11:39 AM Thread Starter
firstresponder
awesome thankyou so much for all your help!
post #4 of 4 Old 06-06-2012, 09:49 AM
Nubian1
2008 WK
How did you make out?
My daughter's '07 2.4L 5spd has the same code after I floored it (I think)
Nubian1 is offline
Patriot ??? wdyer14 Jeep Compass & Patriot Forum 22 04-03-2012 08:26 AM
XJ guy looking at the Patriot xjken99 Jeep Compass & Patriot Forum 13 07-30-2008 08:26 PM
getting patriot, can't decide color! (how is the patriot?) taseal Jeep Compass & Patriot Forum 20 02-08-2008 11:46 PM
yay! i just got one! Patriot jeepersli Jeep Compass & Patriot Forum 3 06-22-2007 03:59 PM
My New Patriot kstiles16 Jeep Compass & Patriot Forum 26 05-11-2007 08:32 PM
