patriot horn - JeepForum.com
post #1 of 8 Old 07-23-2010, 08:49 PM Thread Starter
jdaddy42
2008 MK Patriot
patriot horn
I have an 08 Jeep Patriot and the horn stopped working today. I tried to find the fuse for the horn but, it isn't listed in the manual anywhere. Unless I missed it. Can anyone tell me which fuse it is so I will have a starting point to troubleshoot the horn.
jdaddy42 is offline
post #2 of 8 Old 07-24-2010, 06:43 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
There is no fuse it's part of the Totally Integrated Power Module (TIPM), C11 connector, cavity 9 (X-21) http://www.jeepforum.com/forum/f98/t...module-458804/
It boils down to a bad connector, bad wire, bad ground at the horn, bad horn or bad TIPM.
First check to see if the horn has a good ground at the case.
Next apply direct voltage to the horn with a test lead.
Check wiring and connectors for damage.
If you can check the codes they are:
B2336–HORN CONTROL CIRCUIT LOW - (X21) HORN CONTROL OUTPUT CIRCUIT SHORTED TO GROUND or TIPM.
B2337–HORN CONTROL CIRCUIT HIGH - (X21) HORN CONTROL OUTPUT CIRCUIT SHORTED TO BATTERY VOLTAGE, EXCESSIVE RESISTANCE IN THE HORN OR CASE GROUND, TIPM
B2338–HORN CONTROL CIRCUIT OPEN - TERMINAL DAMAGE OR CORROSION, (X21) HORN CONTROL OUTPUT CIRCUIT OPEN, HORN CASE GROUND, HORN, TIPM.
B2371–HORN CONTROL CIRCUIT OVERCURRENT - TERMINAL DAMAGE OR CORROSION, (X21) HORN CONTROL OUTPUT CIRCUIT HIGH RESISTANCE, HORN CASE GROUND, TIPM.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 8 Old 07-24-2010, 06:54 PM
fortuneer
fortuneer's Avatar
2007 MK Compass
Hmm, Gramps, does that mean I can wire in the new horn I bought before my old one dried out and started working again? If so, that would be sooo awesome! To have two wimpy sounding horns instead of one, LMAO!!! But seriously, can it be done without overloading the single wire?
"There's gold in them hills" (and I'm still stuck in Florida!) ...well, in south Miss now, lol
Black '07 Compass Sport 5-speed 4X4 ("Fortuneer"), K&N filter, cat-back exhaust; RR lift, sunroof, trailer tow group, Boston Acoustic audio, sport bars, rear taillight guards, more to come... Finally got it back from the wife so I can let my Neon R/T rest for a rebuild.
fortuneer is offline
post #4 of 8 Old 07-24-2010, 07:44 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Since the TIPM controls and reads the power going to the horn, off hand I would say NO. It would be drawing too much current to run both just like trying to tap in extra trailer lights with out the relays or run HID's. I think you could run an extra power lead and relay and run more/different horns though. It's a thought.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 8 Old 10-09-2012, 12:46 PM
juliao
2007 MK Patriot
Hello i have a 2.0 patriot crd and have the same problem..just cant find anything bad on horn but it doesn.t work..is it the same scheme as the 2.4 gasoline?
Thank you very much
juliao is offline
post #6 of 8 Old 10-10-2012, 04:53 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Yup, same set up on the body wiring.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #7 of 8 Old 10-12-2012, 09:19 AM
juliao
2007 MK Patriot
Hello again..Just returned from the Jeep dealer here in Portugal and they say the problem is with the clock spring. Here it costs about 600 dollars what i think its too much(more than half my salary) so wonder if you have dealers in USA that can do that cheaper.
Thank you very much
juliao is offline
post #8 of 8 Old 10-13-2012, 07:15 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The clockspring is just a small spring inside the steering column under the steering wheel that connects some of the electronics. It's got to cost less than a $20 bill and many have pulled their own steering wheels to put in cruise control.
Clockspring
Bob
posts 68 & 69
Also visit me at
Gramps is offline
compass , electrical , fuse , horn , mk , patriot
Patriot ??? wdyer14 Jeep Compass & Patriot Forum 22 04-03-2012 08:26 AM
CRD Patriot! tfmr Jeep Compass & Patriot Forum 2 02-01-2010 05:15 PM
08 Patriot zac0386 Jeep Compass & Patriot Forum 9 06-06-2008 01:10 PM
getting patriot, can't decide color! (how is the patriot?) taseal Jeep Compass & Patriot Forum 20 02-08-2008 11:46 PM
We have a Patriot BURNSY Jeep Compass & Patriot Forum 6 02-15-2007 09:22 PM
