Patriot died and wont start - JeepForum.com
post #1 of 14 Old 08-21-2013, 08:08 AM Thread Starter
dpjag
Ok so the old lady was driving her 08 patriot w/ 60K miles and has the 2.4L engine. Left the house and died 1Mi down the road. I looked at it last night and replaced the crank position sensor. I also got a cheapo centech code scanner from a friend and the only code it has was an engine misfire. The car still wont start. It cranks and spudders like it wants to start, but just doesn't have it in her to fire up!
Anything else i should be looking into? Is it possible it is a fuel related issue? pump or filter? I was going to see if i can hear the fuel pump turn off/on after work today.
Thanks,
Darrell
dpjag is offline
post #2 of 14 Old 08-21-2013, 09:38 AM
FujativeOCR
2011 MK Patriot
Coils?
FujativeOCR is offline
post #3 of 14 Old 08-21-2013, 11:09 AM Thread Starter
dpjag
When i seen coil go bad before it will still start... just runs rough.
dpjag is offline
post #4 of 14 Old 08-21-2013, 12:14 PM
FujativeOCR
2011 MK Patriot
I had a Cavalier quit running completely with a bad coil way back when. My volvo only ran rough. Volvo gave a misfire code with it.
post #5 of 14 Old 08-21-2013, 12:31 PM Thread Starter
dpjag
Oh ok ya wouldn't hurt to check them... I am used to Tritan ford engines they will run on a dead cyl
dpjag is offline
post #6 of 14 Old 08-21-2013, 03:46 PM Thread Starter
dpjag
Looked at all spark plugs and one was black and I thought it was fowled and tried a new coil pack and it didn't work.
dpjag is offline
post #7 of 14 Old 08-21-2013, 03:46 PM Thread Starter
dpjag
Also put 4 new plugs in it since they needed it anyway
dpjag is offline
post #8 of 14 Old 08-21-2013, 11:45 PM
FujativeOCR
2011 MK Patriot
Maybe clean the Mass Airflow Sensor? Its easy to get to.
post #9 of 14 Old 08-22-2013, 05:57 PM Thread Starter
dpjag
Ended up being the fuel pump
dpjag is offline
post #10 of 14 Old 08-23-2013, 06:25 AM Thread Starter
dpjag
Does anybody know how much of a pain in the A&% it is to replace the fuel pump on the patriots?
dpjag is offline
post #11 of 14 Old 08-23-2013, 07:05 AM
jacko15
2014 WK
Not sure, but I believe you might have to drop the gas tank to get to it. There must be someone here that knows for sure.
Mine: 2014 Jeep Grand Cherokee Overland V/6
ORA II
Hers: 2017 Jeep Compass Latitude 4x4
jacko15 is offline
post #12 of 14 Old 08-23-2013, 03:32 PM
festerw
festerw's Avatar
Never done it but according to the service manual there is an access panel under the rear seat.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is offline
post #13 of 14 Old 08-23-2013, 05:37 PM
DLTC86
2008 MK Compass
Under rear seat there is an access panel. Above post is correct.
DLTC86 is offline
post #14 of 14 Old 08-26-2013, 01:36 PM Thread Starter
dpjag
Thanks I appreciate it
dpjag is offline
