-   Jeep Compass & Patriot Forum (http://www.jeepforum.com/forum/f98/)
-   -   Patriot died and wont start (http://www.jeepforum.com/forum/f98/patriot-died-wont-start-1565174/)
dpjag 08-21-2013 08:08 AM
Ok so the old lady was driving her 08 patriot w/ 60K miles and has the 2.4L engine. Left the house and died 1Mi down the road. I looked at it last night and replaced the crank position sensor. I also got a cheapo centech code scanner from a friend and the only code it has was an engine misfire. The car still wont start. It cranks and spudders like it wants to start, but just doesn't have it in her to fire up!
Anything else i should be looking into? Is it possible it is a fuel related issue? pump or filter? I was going to see if i can hear the fuel pump turn off/on after work today.
Thanks,
Darrell
FujativeOCR 08-21-2013 09:38 AM
Coils?
dpjag 08-21-2013 11:09 AM
When i seen coil go bad before it will still start... just runs rough.
FujativeOCR 08-21-2013 12:14 PM
I had a Cavalier quit running completely with a bad coil way back when. My volvo only ran rough. Volvo gave a misfire code with it.
dpjag 08-21-2013 12:31 PM
Oh ok ya wouldn't hurt to check them... I am used to Tritan ford engines they will run on a dead cyl
dpjag 08-21-2013 03:46 PM
Looked at all spark plugs and one was black and I thought it was fowled and tried a new coil pack and it didn't work.
Also put 4 new plugs in it since they needed it anyway
FujativeOCR 08-21-2013 11:45 PM
Maybe clean the Mass Airflow Sensor? Its easy to get to.
dpjag 08-22-2013 05:57 PM
Ended up being the fuel pump
dpjag 08-23-2013 06:25 AM
Does anybody know how much of a pain in the A&% it is to replace the fuel pump on the patriots?
jacko15 08-23-2013 07:05 AM
Not sure, but I believe you might have to drop the gas tank to get to it. There must be someone here that knows for sure.
festerw 08-23-2013 03:32 PM
Never done it but according to the service manual there is an access panel under the rear seat.
DLTC86 08-23-2013 05:37 PM
Under rear seat there is an access panel. Above post is correct.
dpjag 08-26-2013 01:36 PM
Thanks I appreciate it
The time now is 11:22 AM.
