patriot/compass problems? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Compass & Patriot Forum > patriot/compass problems?
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 01-25-2012, 05:33 AM   #16
MeganHewitt
2012 MK Compass
I made it just fine on my trip. However, every now and then it takes me a while to get it started. I have to hold the key down for several seconds, probably about 20to or so before it attempts to start. It doesn't do that all the time though.
MeganHewitt is offline   Reply With Quote Quick reply to this message
Unread 01-25-2012, 03:44 PM   #17
Photolithic
I have a 2011 patriot 4x4 FD1. 10,000k miles...the only problem I have had with it...it's not a Wrangler. I think you will like it!
Photolithic is offline   Reply With Quote Quick reply to this message
Unread 01-26-2012, 11:17 AM   #18
Elihawk
2008 MK Compass
yea, I think many of us who have owned Compass/Patriots have had front end issues. I had ball joints and tie rods replaced, with a tire replacement at about 40G miles (previous Car, Mazda Protege, went 150,000 miles before I replaced anything ball joints and tie rods). If that is as bad as it gets, I won't complain too much...just alittle!
Elihawk is offline   Reply With Quote Quick reply to this message
Unread 01-27-2012, 03:29 AM   #19
aberg12012
That seems a little excessive if it's really 20 seconds, but it is normal for any modern fuel injected car to need a few seconds between turning the ignition to "on" and actually cranking the motor.
I have an automatic habit of always waiting about 3 or 4 seconds after I turn on the ignition before actually cranking the motor. It gives the fuel pump and electronics a chance to go through their power-on routine. I think 99% of people just turn the key and crank it at the same time and as such I usually pass off "it takes forever to start" issues with this. But I'm far from an expert, and I could surely be very mistaken.
Yea, I hear that. I've driven a few smaller cars to their death and never really had to worry about ball joints before. My theory is that it's just a matter of having a heavier (at least I assume?) vehicle with more unsprung weight at the end of the suspension to handle. I think it just beats up the strut style suspension which only has one control arm. So that one control arm (and everything attached to it) tends to wear out very quickly. And once a ball joint loosens up, it doesn't take long for the tie rod to also wear out as it's all connected, obviously.
So the more I think about it, the less I guess I'm too worried about it. Especially since now I know how to change them again if need be. She (my wife) really likes the Compass, and after spending the weekend working on it I'm start to fall more in love with it too. I was pretty dead set on trading it in after I fixed the front end. But then I fixed it, fixed the alignment, and realized how nice a car it really is when it's all fixed up.
aberg12012 is offline   Reply With Quote Quick reply to this message
Unread 01-27-2012, 09:21 AM   #20
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I always just turn the key and it starts right up in 5 seconds or less. The very few times it hasn't, less than half a dozen, I turned the key off and waited a couple more second. Not sure if this has anything to do with it but I'm on my third battery too.
Bob
MK Skid Plate fasteners for sale posts 68 & 69
Also visit me at Photobucket
Gramps is offline   Reply With Quote Quick reply to this message
Unread 01-27-2012, 12:12 PM   #21
Elihawk
2008 MK Compass
One small thing that is absolutely wonderful about the Compass (and I assume the Patriot as well)...I have never had a vehicle that was this easy to change the oil and filter! Even a complete novice like me, with almost no hand strength, can easily change the oil on this car.
Unread 01-27-2012, 01:31 PM   #22
aberg12012
You got that right! Although my Subaru is just as easy after you get the belly pan off. Although for the price, I'm still inclined to let my wife take it to Master Lube. Then I don't have to wash it, either.
Unread 01-28-2012, 01:02 AM   #23
Rubes
Our '10 2WD Riot just turned 36k yesterday. Only issue I had to date was the CVT "braking" after you let off the gas. A reprogram (under warranty) fixed it. It's the most used Jeep (I have a TJ, WJ, and KJ) on my driveway. No TRE or CA issues.
You're in Good Hands with Mayhem
Rubes is offline   Reply With Quote Quick reply to this message
Unread 01-28-2012, 03:51 AM   #24
aberg12012
What's the problem with having a little engine braking? Ours does that, and I always thought of it more as a feature than a problem(?) I hate normal automatics and how they coast forever and require riding the brakes when going down hill.
Unread 01-29-2012, 08:17 AM   #25
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Your trans can learn your driving habits and not down shift so harshly if you just let off the gas easily. Mine did.
Bob
Unread 01-29-2012, 02:53 PM   #26
FujativeOCR
2011 MK Patriot
Engine breaking is annoying. Yet another gripe with this whole CVT clusterfluff they put in here. I can't wait to get something with an automatic...in 5 years when the Patriot is paid for :-(
FujativeOCR is offline   Reply With Quote Quick reply to this message
Unread 01-29-2012, 02:59 PM   #27
Busmaster2
I guess it's an acquired taste, but i'm amazed at how powerfully this car can accelerate when necessary. Beleive me, my compass can throw you back against the seats with the best of them..but without the slamming of a regular downshifter. I would liken it to the recoil of a black powder gun vs a modern gun...more of a push as opposed to the whack of a modern gun.
Busmaster2 is offline   Reply With Quote Quick reply to this message
Unread 01-29-2012, 06:32 PM   #28
Rubes
I agree the engine braking is annoying. Couple that with applying the brake, the car almost always feels like you're slamming your brakes. Plus, you never know if the engine braking will cause excessive wear and tear to the tranny.
Unread 01-29-2012, 06:34 PM   #29
Rubes
When we first test drove it, the salesman described the acceleration as a slingshot being released. Yep, it's got some hamsters on steroids under the hood.
Unread 01-30-2012, 01:23 AM   #30
FujativeOCR
2011 MK Patriot
Yup. Every car I've ever had had a smoother drivetrain than this thing. 89 Cavalier Z24, 99 Grand Am, 01 Volvo V70 XC. That doesn't look good for Jeep in my eyes. I mean come on it's 10 years newer!
