Outside temp gauge reads lower than actual temp - JeepForum.com
post #1 of 5 Old 08-15-2010, 11:01 PM Thread Starter
MikeyMLV
This is on my mom's '08 Compass. The outside temperature recently started to display that is was about 20 degrees colder outside than what it really is?
I went through several pages of postings and nothing. One car I had would do that after the carwash but go back to normal. I'm stumped on this one.
Thanks!
MikeyMLV is offline
post #2 of 5 Old 08-16-2010, 05:47 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
See if this helps: http://www.jeepforum.com/forum/f98/a...egrees-867584/
or
http://www.jeepforum.com/forum/f98/r...ompass-434263/
It takes a while after you start driving for it to read right.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 5 Old 08-20-2010, 12:38 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I FINALLY had this problem with mine. I got in to the Compass and it says it's 77 degrees. No way, it was mid 80's. Drove for a couple of miles and no change so then I cycled the options on the screen. It came back to 77 and then started climbing up to 84. Maybe sometimes ya just got to slap it and wake it up.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #4 of 5 Old 08-20-2010, 02:36 PM
merlinTec
merlinTec's Avatar
It should read correct after a 4 hour off time, if less then that it will read lower or the same temp as it was when you turned it off until you drive it for about 15 minutes. this is to stop false higher reading due to heat given off from the radiator/ engine bay.
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #5 of 5 Old 08-20-2010, 02:48 PM
unibus
2007 MK Compass
Thanks for the information... I always thought mine was just messed up.
unibus is offline
ambient temp , compass , mk
Ambient temp sensor stuck on 76 degrees. horsepower Jeep Compass & Patriot Forum 7 08-31-2010 04:02 PM
Gear shift lock-up..easy temp fix tazman900 Jeep Compass & Patriot Forum 0 07-11-2009 04:36 PM
A/C and external temp sensor problems and car won't accelerate gajeepchick Jeep Compass & Patriot Forum 7 09-30-2008 07:20 PM
Temp. Gauge Chriztofor Jeep Compass & Patriot Forum 9 01-26-2008 04:58 AM
Compass ACTUAL mileage Rocky5 Jeep Compass & Patriot Forum 63 01-16-2008 05:00 AM
