Optional tires/wheels for MK's (pg 6 for sizes)
| Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed | Ruffstuff Axle Simple Swap Kit! |
#196 | |
fyi, computer was still rcving signal from sensors in wheels that were in trunk.
#197 |
what does offset hpo, med, fwd mean?
#198 |
The Necessary Evil
![]() Join Date: Aug 2006
This is one of the best links for wheel nomenclature and general info that I've found. Let me know if it answers your questions.
hpo is High Positive Offset Here is another site with good info.
Bob Artificial intelligence is no substitute for natural stupidity MK Skid Plate fasteners for sale posts 68 & 69 Also visit me at Photobucket '06 WK Grand Cherokee Limited Quadra-Drive II, 5.7 '07 MK Compass Limited 4X4, AutoStick |
#199 | |
i want to know if all above doesn't need to use OME to rise car? and what's kind of AR rims to suitable for MK compass? |
#200 |
The Necessary Evil
This list was made before lift kits were available so they all will work with out one except those that are marked Max which may or may not fit. The only problem with the ones that are slightly over 29" is the little nub on the rear of the front fender well that rubs in hard turns. Some people have taken a heat gun and flattened those out to get enough clearance. Just keep in mind that the taller the tire the slower it will be "off the line" and 29" is livable but the dealers can only re-cal the speedo for up to a 28" tire (215/65R17).
I didn't get into the aftermarket rims, way too many manufacturers on those so you'll need to go by what they say is supposed to fit. I do have Kumho 235/60R18 on mine right now with about 30K mile on them and I'll get about another year or 15K on them before I need to buy more tires. At that time I'll be swapping to the 16" Patriot steel wheels that I've picked up and going with either a 225/70R16 or a 235/70R16. There are some really great tread selections in those sizes that would fit what I want in the On/Off Road All Terrain category. I'll also be doing a "rattle can" paint job on the wheels to make them look "different".
#201 |
That's meaning I don't need to lift compass if the new tires are not over size 29" right?
compass limited is with stock wheel specification: bolt 5x4.5(5x114.3mm) offset+45mm now I search new tires+wheel through internet first. How about COOPER tires? many jeep firends recommend this brand, and I'm interested in ATR (70% on road 30% off road) I want to know if smaller wheel is suitable for off road? or small wheel can be found more great tires, such like R16 what you said. finally Hope to see your different wheel soon. haha~
'10 Compass Limited 4X4, AutoStick |
#202 | |||
The Necessary Evil
16" tires have the best availability and price with 17" not being too far behind. The smaller wheel allows for a taller sidewall that helps with ride comfort too. In the last couple of years several manufacturers have expanded their sizes so we have more available than we used to. There are also some "private" label smaller manufactures that make some good tires in the US and that may hold true where you are too or there may be some tires that aren't imported to the US that I don't have information on.
#203 | |
what do you think for my selection above? But i want to know if oil consumption is more than stock compass? as the price of local gas was increased again and again. I can aeecpt a litter bit increase. ![]() How about wheel AR? As I know it's with nice style and good quality in USA. Sorry for bothering you again. ![]()
#204 |
The Necessary Evil
Tires are very subjective and those look nice. The overall diameter difference between the 16/17 is only .09" which only reduces the clearance all the way around by .045", very insignificant. Go with whatever you like.
If you do a lot of in town driving your gas mileage may go down a little, 1 or 2 mpg but if you drive mostly long stretches it may go up a little. It depends a lot on stop and go and how fast you drive. It shouldn't change drastically. I'm not sure what you mean by "AR wheel". Help me out on that one. Never a bother, I'd rather help someone out than Mod.
#205 | |||
![]() AR=American Racing, it's a famous wheel/rims manufacturer in the world, have many many nice styles for JEEP as I know. Such as the photos below: American Racing: Official Manufacturer Website- custom, chrome, polished and painted wheels Thanks for your kindness ![]()
#206 | ||
The Necessary Evil
#207 |
Looking through these posts. Has anyone had any issues with a 235/60/18 tire on stock wheels and stock suspension? I have had 225/60/18 Michelin Primacy MXV4 tires on my Compass with no issues and they are a fantastic tire. I will soon need to replace them I may try to squeeze the 235/60/18 size onto the vehicle. Will they fit without issues?
#208 |
On that maximum tire size... As reported at the "other place", one chap in Australia has managed to run 265/75/16 tires under his Patriot.
That's a calculated overall diameter of 31.6" When asked how he managed that, the answer was "spacers, angle grinder, sledge hammer and a blowtorch pretty much sums it up!"![]() ![]() Looks pretty impressive, doesn't it? ![]()
It's a Jeep Patriot thing. You wouldn't understand. |
#209 |
Junior Member
Has anyone had any problems with bigger tires and warranty issues?
#210 |
I have the hub extensions for my Compass and I fit 15" wheels on pretty easy. The wheels were from a 1992 Comanche.
| Tags |
| 18" tires, compass, patriot, tires, wheels |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
