Optional tires/wheels for MK's (pg 6 for sizes) - Page 5 - JeepForum.com
 1Likes
post #61 of 265 Old 08-08-2007, 08:05 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I found this neat tire size calculator and comparator at 1010tires that I didn't realize was there. If you check the box on the right before submitting it also brings up the tires available in those sizes. It gives width, rim size, height, revs per mile, etc. May be of help to some.
http://www.1010tires.com/TireSizeCalculator.asp
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #62 of 265 Old 08-09-2007, 03:42 PM
jimmysjeepn
2007 MK Patriot
well by trial and error...245/70's will fit and barely rub with one person in the vehicle...it would appear for now that 235/70's will be the way to go...
2007 Patriot
2.4L, FD1
jimmysjeepn is offline
post #63 of 265 Old 08-09-2007, 08:43 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I’ve been looking at tires a lot myself. Crawling around under my Jeep, measuring clearances and taking a few pictures. My tires are the 215/55TR18’s that are 6.4” tread width, 8.8” section width and 27.4” tall, all measurements are in relationship to my tires of course.
The real culprit that gets in the way of taller tires is the struts. Between the top of my tire and the anchor plate for the spring is only about 1 ¼ “. That means that the max I could go is a 2 1/2’ taller tire or 29.9” and at that it would be rubbing on the spring anchor just sitting still . The only way that I can see to go any tires taller than about 29” is either with modified struts or wheel spacers. The latter will never be on my want list and since I don’t make struts in my back yard that’s going to have to wait too. Even the FD II Patriot uses about the same strut, just stiffer I believe, same spring anchor. So even though its GC is at 9” you still won't be able to put a taller tire than the 29” . Here are some pics to show what I’m talking about.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #64 of 265 Old 08-14-2007, 07:13 PM
Ole Yeller
Ole Yeller's Avatar
2010 JK Wrangler
patriot lug bolt pattern 5 x 4 1/2?
Is the Patriot 5 x 4 1/2 like the Wrangler and Cherokee? Also, I am assuming it is the same as the Compass???
2007 Patriot Limited
2006 Unlimited Rubicon
2006 Commander
2000 TJ Sport
My previous Jeeps
1992 Wrangler S (Ole Yeller)
1985 Cherokee Pioneer
1989 Cherokee Laredo
1995 Cherokee Country
1996 Cherokee Country
1996 Grand Cherokee Laredo
Ole Yeller is offline
post #65 of 265 Old 08-14-2007, 07:32 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Yes it is.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #66 of 265 Old 08-15-2007, 12:57 PM
Ole Yeller
Ole Yeller's Avatar
2010 JK Wrangler
Ok......now one last query..... Will the 15 inch Ravine wheels fit a Patriot? In other words with the 15 inch wheels clear the brakes etc?
2006 Commander
2000 TJ Sport
My previous Jeeps
post #67 of 265 Old 08-15-2007, 01:13 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Same here. . I can't answer that one. The off-set on the MK wheels is 38/42/45mm (I've seen differences between Manufacturers). Not a clue on the Ravine's. I could try and take a picture when it dries out up here or go take a look at these shots. http://www.jeepforum.com/forum/showp...7&postcount=39
to maybe get just an idea. They do show a little of the brake lines with 18” wheels but they weren’t intended to show the clearance for them.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #68 of 265 Old 08-16-2007, 02:27 PM
YeepYeepin
2009 JK Wrangler
I got New Tires on the 4 x 2: pics on camera upstairs; will post this afternoon/ evening.
So I went up to Pepboys yesterday and got new tires. With the base base model, I got the fantabulous 205 70's on my Patriot and every time I looked at her profile, I said to myself ' now somethin' about that just aint' right. ' So like usual, I had to go and try to fix something that wasn't broke.
The manager there was convinced we could make 245 75's a go, but no such luck. (I didn't think it'd be too polite with the whole ' i told ya so' from all my research on the forums. So, we went down to 235 70 series, and they look and fit great.
The da** Hurricane's blasting us with rain today so I haven't been able to measure how much higher she sits, but it's at least half n inch. Pulled up to a light last nigth right next to an old grand like mine, and the Pat's mirror was the same height. I'm ecstatic. She looks like a real Jeep now.
tried to make the tires rub and the only time they did was on a full blown hard turn...no big deal to me; if they rub, they'll do it a few times and then the wheel wells will be 'altered' to fit the ties. No up and down suspension rubs over speed bumps up to 20 mph.
YeepYeepin is offline
post #69 of 265 Old 08-16-2007, 04:32 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
That's the kind of feedback that I've been waiting for.
Stock ground clearance with the 205/70R16 is 8" (4 X 2).
the 235/70R16 are 1.65 taller than the 205's (27.28 vs 28.93) gives you a total GC of 8.83".
SWEET!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #70 of 265 Old 08-16-2007, 06:34 PM
jimmysjeepn
2007 MK Patriot
As stated before, I have 235/70/16's on stock Rubicon wheels and there is NO rubbing at all, even with 4 adults inside the vehicle. Ill post pics here in about 15 minutes....It looks sweet. My buddy looked at it (he has a brand new sahara 4 door wrangler) and said "wow, they should come stock like that". Which is why I like using the rubicon wheels. It gives it a stock look but makes it look great. Pics to finally follow.
2007 Patriot
2.4L, FD1
post #71 of 265 Old 08-16-2007, 07:31 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
For jimmysjeepn. THESE ARE LOOKIN' GREAT!!! 28.5" - 29" sure looks Right. They should have been stock!
Gramps is offline
post #72 of 265 Old 08-17-2007, 07:40 AM
vaaggg
2007 MK Compass
!!! I am excited!!! I want them on my compass!!!!!!!!!
Gramps the tire size is 235/70/16 (pix above), right?
Jeep Compass 4WD CVT Limited Black
Palio Faliro - Athens - Greece
vaaggg is offline
post #73 of 265 Old 08-17-2007, 08:10 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Confirmed, and that's 29"! I'm excited too! Do you have 17" or 18" on your Compass? The 29" tires for 18" wheels works out to 235/60R18 (29.1); 235/65R17 are 29.02. Without going to a different off set on the wheels, spacers or redesigned front struts, these could be our optimum choices. By all means, play around with the tire size calculators and find the tread pattern that's right for your driving conditions!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #74 of 265 Old 08-17-2007, 09:52 AM
vaaggg
2007 MK Compass
Yeah I have 18''... Thanks for your info!!!!
(still excited hehe)
vaaggg is offline
post #75 of 265 Old 08-17-2007, 10:39 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I wasn't sure if the export Limited still used the 18" wheels, Thx!
A reminder to everybody who will be moving up in tire size. Your speedometer WILL BE OFF by about 6%; 60 mph = 56 actual and 100kmph = 93. The dealer can recalibrate your speedo if you can't live with it.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
18" tires , compass , patriot , tires , wheels
Lifted or lowered MK's pdxbubba Jeep Compass & Patriot Forum 79 05-09-2016 11:40 AM
Sport Bars and Baskets for MK's Gramps Jeep Compass & Patriot Forum 99 03-13-2012 09:58 AM
HID kit problem on MK's Laloggia Jeep Compass & Patriot Forum 78 10-22-2011 08:50 AM
Upgrades included in '09 MK's Gramps Jeep Compass & Patriot Forum 7 07-09-2008 08:14 PM
MK's to be updated. unclejjg Jeep Compass & Patriot Forum 43 04-20-2008 02:02 PM
