Optional tires/wheels for MK's (pg 6 for sizes) - Page 3 - JeepForum.com
 1Likes
post #31 of 265 Old 05-28-2007, 10:03 AM
CaptainJim
Originally Posted by Gramps
Do you mean a 235 tire or ? Do you have a link to the rim site? Looks like your going with the Startech look!
He must cuz here's my Wrangler with 305/55 20 Nitto Terra Grapplers on. That measures out to just over 34"
I also just picked up my 07 Patriot Limited ... love it for all different reasons I love the Wrangler!
Gotta get a couple pics up.
Capt. Jim
CaptainJim is offline
post #32 of 265 Old 05-28-2007, 01:29 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Capt. Jim
Please do! Maybe you could start off the Patriot Owners Pic sticky.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #33 of 265 Old 06-04-2007, 07:35 PM
zxjockey
2007 MK Patriot
Greetings all;
I just picked up my Pat Limited last week. I'm sure I'll have about 5000 questions for you folks, but I wanted to start with the tires. There is a lot of good stuff here on the tire sizes. I'm wondering if, since these posts were last current, has anyone got any new opinions on upping the P size? I'm looking at getting rid of the Firestones that came with my Pat, and I want to go with the Forterra 225/65/17, since the Forterra starts out at 225. My alternative, if I want to keep to the DC numbers, would be the Assurance 215/65/17. I like the tread on the Forterra a whole lot better. The Nominal Pressures on the 225 Forterra are equivalent to the Firestones on my Pat now. So although the TPMS is calibrated to "Size," does the calibration actually have anything to do with physical size, or just pressure? Has anyone gone over the 215 DC limit yet, and with what results? Any opinions on whether they can void my warranty if I go to a 225?
Thanks
zxjockey is offline
post #34 of 265 Old 06-04-2007, 08:23 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I'll offer some opinions based on what I've found out so far.
pillzny has posted pictures of his Compass with 245/35/20 here:
http://www.jeepforum.com/forum/showp...6&postcount=14
The Startech Rallye is also running 20 inchers.
I may be be going with Pirelli P235/60TR18 when my stock P215/55R18 wear out. It will most likely be out of my warranty when that happens.
I think that the TPMS senses a change in volume. That's what it appeared to do when I got a slow leak from a nail.
The 225/65/17 are 28.52" tall, only 1/2" taller than the ones that you have now with the better tread design as you mentioned. If I had a Patriot those are probably the ones that I would go with.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #35 of 265 Old 06-04-2007, 08:32 PM
zxjockey
2007 MK Patriot
Wow, thanks for that quick answer! Do you think my warranty will be ok under those conditions? Have you heard of anyone having problems along those lines?
zxjockey is offline
post #36 of 265 Old 06-04-2007, 08:37 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I haven't heard of vehicle warranty problems. Does anybody else have any info?
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #37 of 265 Old 06-07-2007, 05:56 AM
madrabbitt
madrabbitt's Avatar
There should be no problem with warrenty if you're changing "consumables" like tires. There should be a size range specified somewhere, like the door panel or in the glove box, maybe the manual, that says all the sizes that come stock, and the correct pressures.
on the subject of pressure, there shouldnt be too much of an psi change on that size tire.
the cherokee had 5 sizes stock through the entire span, from 195 stock minimum to 235 option on some off-road packages. Pressure was 30 cold on all the sizes.
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
post #38 of 265 Old 06-07-2007, 06:32 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Post #64 lists ALL of the factory recommended tire sizes.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #39 of 265 Old 06-07-2007, 07:19 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
no pics = no bigger tires.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #40 of 265 Old 06-07-2007, 07:26 AM
madrabbitt
madrabbitt's Avatar
wha, you think i read the long posts with numbers?
post #41 of 265 Old 06-07-2007, 07:44 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Sorry I didn't have big pictures to fill your screen
Here's the cliff notes version.
P205/70R16=27.28in
P215/60R17=27.16
P215/65R17=28.00
P215/55R18=27.31
Please
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #42 of 265 Old 06-07-2007, 09:26 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Nope,
JF has very specific unwritten rules.
1. Don't brag about something you've done to your Jeep unless you can back it up.
2. Pictures always serve as backup.
3. See rule #1.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #43 of 265 Old 06-07-2007, 10:03 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
OK, fine! "31" BFG Mud Terrain tires on 16'' Jeep Moab rims supplied by Prime Wheel". You'll never get to be in first place by following.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #44 of 265 Old 06-07-2007, 07:13 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Thanks. We all enjoy a visual.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #45 of 265 Old 06-08-2007, 06:12 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
BTW - a 31" tall tire in 16" rims comes out to a 255/75R16 tire.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
18" tires , compass , patriot , tires , wheels
Lifted or lowered MK's pdxbubba Jeep Compass & Patriot Forum 79 05-09-2016 11:40 AM
Sport Bars and Baskets for MK's Gramps Jeep Compass & Patriot Forum 99 03-13-2012 09:58 AM
HID kit problem on MK's Laloggia Jeep Compass & Patriot Forum 78 10-22-2011 08:50 AM
Upgrades included in '09 MK's Gramps Jeep Compass & Patriot Forum 7 07-09-2008 08:14 PM
MK's to be updated. unclejjg Jeep Compass & Patriot Forum 43 04-20-2008 02:02 PM
