Oil Filter Access - JeepForum.com
post #1 of 8 Old 07-23-2008, 11:40 AM Thread Starter
the mad hatter
Oil Filter Access
Okay this may be the most noobish question ever...
2007 Patriot Ltd.
What is the best way to access the oil filter? I can't even seem to see it from the wheel well/underneath the vehicle.
Thanks.
the mad hatter is offline
post #2 of 8 Old 07-23-2008, 11:51 AM
schoat333
2008 MK Patriot
there is a hole cut in the bottom plastic, Or skid plate if you have it. Its on the side of the engine, under the intake manifold. (front of vehicle)
schoat333 is offline
post #3 of 8 Old 07-23-2008, 12:00 PM Thread Starter
the mad hatter
Thanks. I saw the hole for the drain plug. So there is another hole for the filter?
post #4 of 8 Old 07-23-2008, 12:01 PM
Elihawk
2008 MK Compass
I have a Compass, but I assume the access is the same...directly in "front" of the oil pan and perhaps the easiest Oil filter I have ever had to access/change. I think even Jiffy Lube could get this one right...
Elihawk is offline
post #5 of 8 Old 07-23-2008, 12:37 PM
Argent33
2014 JK Wrangler
Hmm do you have the Trail Rated Patriot?
if so you might need to remove the skid plate to get to the oil filter
either way it should be right on the front side of the block - I just changed my Compass oil and it was really easy to find.
~Paul
-[O l l l l l l l O]- 2014 Freedom Edition JKU - Hydro Blue 6-Spd
Argent33 is offline
post #6 of 8 Old 07-23-2008, 12:46 PM Thread Starter
the mad hatter
I don't think it's the trail rated one...there's no badge saying so anyways.
When you guys are saying 'front'. Are you referring to the actual front of the vehicle, or the theoretical front of the engine where the belts are?
post #7 of 8 Old 07-23-2008, 02:08 PM
schoat333
2008 MK Patriot
The patriot's engine is tranverse mounted so the front of the engine is technically on the passenger side. In the case of the oil filter we are refering to the front of the patriot itself.
The oil pan hangs down quite a bit lower than the filter so youll have to get underneith the patriot and look up thru the hole to see it.
Hope this helps.
post #8 of 8 Old 07-23-2008, 02:59 PM Thread Starter
the mad hatter
Hope this helps.
Gotcha...that would explain why I never saw it. I kept looking towards the passenger side of the engine...not the front of the vehicle.
Thanks for your help!
Engine Air Filter replacement in 2.4 MomofCandS Jeep Compass & Patriot Forum 10 05-29-2009 07:31 PM
Fuel Filter question PirateKatz Jeep Compass & Patriot Forum 8 01-26-2009 05:23 PM
Where is the Cabin Air Filter? UTAH Jeep Compass & Patriot Forum 19 12-16-2008 07:25 AM
Oil amount w/ filter, how much? Tuksonrider Jeep Compass & Patriot Forum 3 10-08-2008 12:01 PM
K&N Air Filter - Compass CRD mdls4 Jeep Compass & Patriot Forum 7 01-30-2008 03:05 PM
