Oil Changes - JeepForum.com
Go Back JeepForum.com > Models > Compass & Patriot Forum > Oil Changes
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSavvy Billet LED Tail LightsWant to be able to SEE? DOT Approved Headlights for under
Unread 09-28-2014, 07:28 AM   #1
bublhead79
Oil Changes
My wife has a 2014 Jeep Patriot. In reading the owners manual, it sounds like different drivers have different oil change requirements. What has everybody else experienced as far as mileage goes before needing to change the oil?
bublhead79 is offline   Reply With Quote Quick reply to this message
Unread 09-28-2014, 03:58 PM   #2
Redpine
2014 MK Patriot
Our driving is a mix of suburban and rural, summer/winter. Short and medium trips with very occasional expressway miles. My Oil Life Monitor (OLM) has been going off between 6,000 and 7,000 miles. Now that my Pat is thoroughly broken in (+10,000 miles +/-), I am going to do a Used Oil Analysis at some point to confirm that the OLM is trustworthy.
So much has changed regarding oils and it was tough to shed the 3K/3month myth that I grew up with. This is the first car I have had with an OLM, the first time I am going beyond 5,000 mile oil changes, and also the first time using "synthetics" (group 3 Pennzoil Platinum).
Yes, driving styles and conditions will alter the the life of the oil quite a bit. But, today's oils are so much better compared to even just 10 years ago. Engines with fuel injection and MANY other improvements run much cleaner today also.
Visit Bob is the Oilguy if you want to get sucked into this subject area.
Redpine is offline   Reply With Quote Quick reply to this message
Unread 09-28-2014, 11:24 PM   #3
merkurman
2014 MK Compass
I am seeing about the same mileage...
My Compass is my company vehicle that sees about 3-4k per month...I got my truck on 7/8/14 and it is ready for its 2nd oil change...lots of highway/lots of city driving but the oil monitor kicks in about 6k miles each time...Since the dealership does the maintenance I have not run an oil test yet... But my Charger R/T has the same monitor and it also kicks in about 6k miles too...And its oil has been tested and it is fine so far,,,
merkurman is offline   Reply With Quote Quick reply to this message
Unread 11-28-2014, 12:52 PM   #4
caulk04
2008 WK
Wife's '14 requested the first oil change at ~8600 miles. I changed it once at 1000mi.
It's nearing 15k miles and hasn't yet requested another change. Manual states no more than 10k, I won't go over 9 even though I use Mobil1 synthetic.
Tint, Superchips, SRT intake tube, Gibson catback, catch can. One hardcore DD/kid hauler...yeah.
caulk04 is offline   Reply With Quote Quick reply to this message
Unread 12-06-2014, 02:16 PM   #5
miketmx
2008 MK Patriot
IMHO the oil change monitor is the 2nd most useless feature of our Patriot right after the TPMS. I believe the monitor is based strictly on mileage and in no way can measure oil quality after short trips or mostly highway driving. I change oil after 5k miles and I use synthetic and we have over 150k miles on our 2008 Jeep.
miketmx is offline   Reply With Quote Quick reply to this message
Unread 12-08-2014, 10:21 AM   #6
JerryGNYC
2015 MK Patriot
From the owners manual - "The engine oil change
indicator system is duty-cycle based, which means the
engine oil change interval may fluctuate dependent upon
your personal driving style."
From my experience, I'd believe it to be true...
- Common sense is on perpetual backorder.
JerryGNYC is offline   Reply With Quote Quick reply to this message
Unread 12-10-2014, 10:38 AM   #7
caulk04
2008 WK
It's the same way on my 08 WK. The PCM has some crazy algorithm that will trigger an earlier OCI if you constantly do short trips or run heavy throttle etc etc.
That said, I change the oil in my WK every 6 months which works out to 5-6k. I don't like letting oil go longer than 6 months but I have no problem with going 7-8k.
Unread 12-10-2014, 01:40 PM   #8
JerryGNYC
2015 MK Patriot
And FWIW, my experience with our 2012 Chrysler 200 (3.6L) also backs up duty-cycle based monitoring. More highway driving, longer OCI intervals.
