'Oil Change Required' Message - JeepForum.com
post #1 of 3 Old 05-08-2012, 02:09 PM Thread Starter
mdneve
I traded in my 1996 Cherokee 4.0L Petrol for a 2009 Patriot Diesel on Friday. When I went to drive away the 'Oil Change Required' message was illuminated. This was reset by following the procedure of depressing the accelerator three times within 10 seconds. The message was not displayed the next time I started the Patriot but returned the time after that. I have now reset several times over the weekend. The reset procedure seems to work initially but the message then returns.
The oil was apparently changed immediately before I collected the Patriot. I understand the indication is based on duty cycle. What parameters are measured ? Is this definately an eroneous indication ? How can it be reset ?
Thanks
mdneve is offline
post #2 of 3 Old 05-08-2012, 07:19 PM
BrandonLong
Have you verified the oil was changed?
-Brandon
BrandonLong is offline
post #3 of 3 Old 05-09-2012, 05:50 AM
ddavidv
2008 MK Patriot
I don't believe the 'system' has any clue nor cares if the oil is actually changed or not. I believe it is set by mileage and/or cycle times of the ignition switch.
ddavidv is offline
oil change indicator , oil change reminder
First message center on 2007 compass Kwelch12 Jeep Compass & Patriot Forum 11 07-11-2011 11:53 AM
Early Change Oile Message wesleyd Jeep Compass & Patriot Forum 10 11-05-2009 06:32 PM
Help: Check TPM system message plunderisley Jeep Compass & Patriot Forum 7 06-08-2009 05:57 PM
Required maintenance. neronak Jeep Compass & Patriot Forum 3 10-11-2008 10:28 AM
Wheel Spacers Required on my FDII with RRO Lift AZ_Boilermaker Jeep Compass & Patriot Forum 4 08-25-2008 06:39 PM
