Oil change indicator - JeepForum.com
post #1 of 26 Old 02-13-2008, 11:19 AM Thread Starter
Trek620
2008 MK Patriot
Hello all;
Does anyone have insight about how the oil change indicator in the dash works? Mine lit up already and my Patriot is only 2 1/2 months old with 2,500 miles. The manual says the indicator is "duty based" and affected by driving style. I'm a gentle driver and change the oil in my other vehicles every six months. What gives?
Thanks
Trek620 is offline
post #2 of 26 Old 02-13-2008, 11:55 AM
CharBroiled
cant say specifically for the patriot but cadillacs oil change monitor bases it on miles, temps, stop and go, speed, how hard you drive it, stuff like that. I would think the patriots monitors the same stuff.
so it might go 4500 miles if its mostly highway driving and 2000 miles if its a lot of city driving. highway miles are kind to oil as any moisture/fuel byproducts in the oil "burn" off. short trips are harsh to oil as moisture/blowby products just collects as the oil never gets and stays hot enough for it to evaporate or "burn" off.
those in the know will chime in with more accurate info though.
2000 Cherokee Sport 4.0L Selec Trac - mine - for occasional wheeling
2007 Patriot 2.4L FD I 4x4 - wifes - doomed to rarely leave the street
CharBroiled is offline
post #3 of 26 Old 02-13-2008, 01:37 PM
Urr
Keep it simple:
1. If it lights up, check the oil. That's what it's for
2. "A new engine may consume some oil during its first few thousand miles (kilometers) of operation" --- Compass manual, page 39.
So you can't compare it with your other vehicles... yet.
Happiness is not a goal, but a lifestyle
Ex 2007 Jeep Compass Sport 4x4 CRD
DD 2011 Mitsubishi ASX Invite 4WD DiD
In bright and happy future: Jeep Wrangler
Urr is offline
post #4 of 26 Old 02-13-2008, 03:16 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
If you change your own oil, this is what you do.
Engine Oil Change Indicator System
Oil Change Required
Your vehicle is equipped with an engine oil change indicator system. The “Oil Change Required” message will flash in the EVIC display for approximately 10 seconds after a single chime has sounded to indicate the next scheduled oil change interval. The engine oil change indicator system is duty cycle based, which means the engine oil change interval may fluctuate dependent upon your personal driving style.
Unless reset, this message will continue to display each time you turn the ignition switch to the ON/RUN position. To turn off the message temporarily, press and release the Trip Odometer button on the instrument cluster. To reset the oil change indicator system (after performing the scheduled maintenance) refer to the following procedure.
1. Turn the ignition switch to the ON position (Do not start the engine).
2. Fully depress the accelerator pedal slowly three times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you start the vehicle, the oil change indicator system did not reset. If necessary repeat this procedure.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 26 Old 02-13-2008, 09:37 PM
jbjeepguy
2007 MK Compass
Do all MKs have this?
So do all MKs have the oil monitor system? Was this a running production change? There is not any mention of it my owners manual- just the standard service interval tables.
I bike therefore I work.
07 Compass, FDI, CVT
jbjeepguy is offline
post #6 of 26 Old 02-13-2008, 11:36 PM
taseal
1993 XJ Cherokee
its in there. can't remember what page though.
my '93 (and '89) BMW had it lol
'93 Cherokee "XJ" Sport - 4.0 HO - 4x4 - AX15 - Chrysler 8.25 - Fun Jeep
'08 Patriot "MK" Limited - 2.4 - 4x2 - CVT II -DD Jeep
taseal is offline
post #7 of 26 Old 02-14-2008, 04:16 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
It's in the 2008 Patriot Owners Manual, pg 178, and the 2008 Compass Owners manual, pg 172. It is not a feature on the 2007 Compass and I don't know the date change. There is no 2007 Patriot Owners Manual on line so I can't check that one out. It's under "Understanding Your Instrument Panel".
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #8 of 26 Old 02-14-2008, 06:01 AM
CoriolisSTORM
WHAT?!
CoriolisSTORM's Avatar
2010 JK Wrangler
I don't think my Caliber has that... I think it was a change... Too bad they STILL didn't do the washer fluid level!
1998 TJ Wrangler SE - Stone White, 2.5Ls of screaming lifter clacking power, AX5, 31" BFGoodrich All Terrain T/A KOs
2010 Wrangler Unlimited Sahara - Deep Water Blue, 3.8Ls of oil consuming fury, NSG-370, BFGoodrich Rugged Terrain T/A 265/70/R18s
CoriolisSTORM is offline
post #9 of 26 Old 02-14-2008, 07:59 AM
jbjeepguy
2007 MK Compass
Thanks
'07 Compass so I am correct- no oil monitor system.
post #10 of 26 Old 02-14-2008, 01:39 PM
CharBroiled
man folks today are spoiled.. back in the day we just waited till the engine started making noises like a diesel.. THEN we changed the oil.
BTW our 07 patriot doesnt have an oil change monitor either, manual just says every 3 months/3000 miles.
wonder if it could be added if you have EVIC, Im wondering if its just a software algorithm.
post #11 of 26 Old 02-14-2008, 04:55 PM
Jeepster55
Originally Posted by Gramps View Post
...... It is not a feature on the 2007 Compass and I don't know the date change.
Bummer.........
Jeepster55 is offline
post #12 of 26 Old 02-14-2008, 05:03 PM
CoriolisSTORM
WHAT?!
2010 JK Wrangler
I went 10,000 past on my Wrangler 2.5L one time. It was fine though, still runs good at 78,000 miles! (Again, happy 10th b-day baby!)
post #13 of 26 Old 02-14-2008, 05:28 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
When yer lifters start clackin' it means that yer down two quarts. They either burned off or leaked out. Time to put some more in but while yer at it ya' might just as well change it, it's only a couple more quarts and a filter!
When ya' go to use the windshield washer and it don't squirt, it's frozen or empty! Thaw 'er out or fill 'er up fer the next time.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #14 of 26 Old 02-15-2008, 06:31 AM
bpb_21
2008 MK Patriot
Patriot 2008 oil change & powertrain warranty
Hey all - I've got a basic question many of you may roll your eyes at, but bear with me here...
I got a Jeep Patriot 2008 model last November (of 2007) and it's been great - just what I wanted out of it. It also comes with this "lifetime powertrain warranty" if you follow the scheduled maintenance in the manual. The first scheduled maintenance in the manual is at 6,000 miles, where you get the oil changed, tires rotated, so forth. Here's my (paranoid) question:
I traded in a Jeep Cherokee 1994 Sport that I got new in...well...1994. I put over 250,000 miles on the Jeep (actually more like 280k), changed the oil every 3,000 miles the entire time I had it, and never had to replace the engine, transmission, or any major engine components (I did replace the rear bumper 4 times - apparently other drivers have a hard time seeing a big, "flame red" jeep they're coming up on too fast!). Point: I've always lived by changing the oil every 3,000 miles and it's worked out quite well for me.
The manual has the oil changes at 6,000 miles and these new-fangldy vehicles have the oil sensors and whatnot. I plan on keeping the Patriot for 13 or 14 years, just like the Cherokee, so should I be changing oil every 3k or just sticking with the manual at 6k? I do a mix of highway and city driving, but I never really encounter "traffic jams" where I'm stuck idling for a while. I'm not off-road with it so much but I do use it to haul landscaping supplies on occasion (cleans up very nicely, I've found).
Anyway, I'm taking it from the posts on this thread that if the change oil light hasn't come on (it hasn't) and I haven't hit the 6,000 mile oil change interval from the manual then I'm ok. I'm a real stickler for maintenance, and slightly paranoid with it being brand new, so I figured I'd run this by the pros on the forum here. Thanks for entertaining the question!
bpb_21 is offline
post #15 of 26 Old 02-15-2008, 07:07 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The '07 manual calls for 2 different schedules, one for 3K the other for 6K depending on the service. I'll need to look at the '08 manual to see if there is anything on that. I have been changing mine religiously every 3K but I'll be switching to synthetic soon and following the oil manufacturers recommendation and using their warranty.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
change gear/shifter know mrplow Jeep Compass & Patriot Forum 1 01-13-2010 09:12 AM
Oil Change pshingle Jeep Compass & Patriot Forum 13 07-02-2009 12:15 PM
Oil change question Skipsjh Jeep Compass & Patriot Forum 8 06-03-2009 03:58 AM
Should I be worried about oil change indicator? udmover Jeep Compass & Patriot Forum 3 09-03-2008 07:06 AM
How to change out the radio?? lynnk Jeep Compass & Patriot Forum 10 11-01-2006 05:50 PM
