Oil change indicator - JeepForum.com
post #1 of 8 Old 11-19-2012, 05:59 PM Thread Starter
acedl
2012 KK Liberty
Hey everyone.,
My wife has a 09" patriot. How do i reset the oil change light?
Thanks!
acedl is offline
post #2 of 8 Old 11-19-2012, 06:02 PM
FujativeOCR
2011 MK Patriot
I think you turn the key to the on position, press the accelerator 3 times, then key off, step outside, look at the car and say to the car "you see car? There is nothing you can possess which I can not take away!"
Light shouldn't come back on for 4,000 miles or so.
FujativeOCR is offline
post #3 of 8 Old 11-21-2012, 04:27 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Isn't that in the Owners Manual?
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #4 of 8 Old 11-23-2012, 12:00 PM
jacko15
2014 WK
Yes:
"1. Turn the ignition switch to the ON position. Do not
start the engine.
2. Fully depress the accelerator pedal, slowly, three times
within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
reset. If necessary repeat this procedure."
pdf of manual available here:
http://www.autorepairmanualsz.com/10...pdf-download/#
jacko15 is offline
post #5 of 8 Old 11-24-2012, 06:10 PM Thread Starter
acedl
2012 KK Liberty
Great all set guys. Thanks!
acedl is offline
post #6 of 8 Old 11-26-2012, 12:52 PM
NHPATRIOT
2014 KL Cherokee
Light comes back on based on use not preset # of miles.
2014 Jeep Cherokee
Latitude
3.2L Pentastar V6
Active Drive I
NHPATRIOT is offline
post #7 of 8 Old 11-26-2012, 03:22 PM
FujativeOCR
2011 MK Patriot
From what i understand it can be use or miles. Not sure what the interval is, but somebody's on here went off like 1,000 miles after an oul change, as has mine, so 4,000 is probably a good guess.
post #8 of 8 Old 11-29-2012, 03:32 PM
NHPATRIOT
2014 KL Cherokee
It is use based not miles.
2014 Jeep Cherokee
Latitude
3.2L Pentastar V6
Active Drive I
