Off-road safari on May 16th - JeepForum.com
post #1 of 7 Old 06-29-2009, 01:14 AM Thread Starter
Tony1911
2007 MK Patriot
Yes, it took me a little while to post this, didn't it... All pictures are taken by my girlfriend.
On May 16th, Finnish Jeep Drivers Club held their annual spring safari in Ravijoki. The place was advertised as having suitable terrain for all kinds of vehicles, so my girlfriend and I decided to take part. I'm very glad we did!
Upon arrival, vehicles were divided into different groups according to their off-road capability. As always in Finland, most vehicles to show up were built up off-roaders, so our little SUV ended up being the only member of group three. The trail guides didn't seem to mind, so we wound up following a Wrangler around a couple of the easier trails by ourselves.
The trails we rode were easy forest trails with some hair-rising off-camber climbs and downhills thrown in. Like I was told at the FJDC forum, a good place for any vehicle to try real off-roading in! Ground clearance was never a problem on these trails, however lack of articulation combined with open differentials (thanks, you cheap bastards at Chrysler...) was. On a couple of the climbs I lost traction, which might partially be a tire issue, partially articulation issue. (My anti-roll bars were connected, as the stock brake lines really do not look to me like they can handle any extra articulation. It would be interesting to see how the vehicle would handle itself with the roll bars disconnected, but something really needs to be done to those brake lines first!) The Yokohama All-Terrain tires I had did not seem to deform significantly at 25PSI, on the other hand I was told that when driving over some rocks there wasn't all that much tire left between the rim and the rock so deflating much more than that was inadvisable. Going for smaller rims for more side wall would probably be a good thing.
Trail damage was largely avoided. Some scrapes on the sides from tree branches but nothing that penetrated through the paint, a tiny scratch on the plastic rocker panel and somewhere along the last and biggest climb, which turned out to be quite a struggle and in the end required winching to get the Patriot up it, the front bumper scraped against a tree, leaving a small mark.
And finally, the pictures:
Following the guides in their Wrangler.
Just a view from the trail
A typical view of the trail from inside the vehicle.
This descent doesn't look like much on camera, but teetering on two wheels on top of it was quite exciting enough for a rookie like me.
Spin, spin, spin your wheels... Here we see a troublesome spot on the trail. As you may be able to barely see, the trail slopes quite a lot on the right. I am trying to aim for the left edge of the trail without hitting that tree on the left, but my right front wheel still loses traction. It remains unclear whether my left rear wheel had traction at this point or whether it was spinning too. In the end, clearing this little knob required a slight pull with a tow strap. In hindsight, if the rear axle had traction, more power might have helped. (I had the ESP fully off the whole time - not sure if a different mode would have made a difference. I was too busy trying to find a good line to think about this stuff. I reckon I need more practice at this stuff. )
Lining up for a new try on the same climb.
It's a Jeep Patriot thing. You wouldn't understand.
Tony1911 is offline
post #2 of 7 Old 06-29-2009, 01:21 AM Thread Starter
Tony1911
2007 MK Patriot
May 16th safari, continued
Start of the second trail.
We stopped to look at an old WWII era fortification. The place was strictly "bring your own flashlight", so alas, no pictures from the inside.
Continuing along the trail. My girlfriend said she tried to get a picture that was as level as possible, but the ground was a tad rough so it was hard to say where "level" was. The trees on the right really were leaning a little towards the trail, so the image should not be too far off.
A different view of the same descent.
It might not look like much in the photo, but it sure felt like we were leaning quite a bit to the left.
A better view of the amount of lean at the same spot of the trail.
Tony1911 is offline
post #3 of 7 Old 06-29-2009, 03:16 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Thanks Tony! Copied to the QUICK LINKS sticky. Really looks like a good time. Do the export Patriots have the rear cargo/flash light combo like the NA models? That "bunker" looks interesting!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #4 of 7 Old 06-29-2009, 04:58 AM Thread Starter
Tony1911
2007 MK Patriot
Yeah, we have the flashlight. It's not very powerful though - I used my Surefire with a Cree LED drop-in conversion and my girlfriend used the Streamlight Scorpion I keep in the glove box. Much better for going from a bright almost-summer day straight into a dark bunker. Still, the flashlight is nice to have - it's a cute gadget (and I'm always for any cute gadgets! ) and a backup that doesn't take any extra room.
Tony1911 is offline
post #5 of 7 Old 06-29-2009, 09:46 AM
Knightfallzx2
2008 MK Compass
I see yours is FDI, not II. Awesome. Another thread to show the wife next time I speak of taking the Compass on an easy trail. (Not saying your trail was easy. But if an MK can do that trail, our MK could definitely do an easier one.)
2008 Jeep Compass North 4x4
Black Crystal Pearlcoat, 5-speed
Knightfallzx2 is offline
post #6 of 7 Old 07-02-2009, 03:09 AM Thread Starter
Tony1911
2007 MK Patriot
Hey now - no reason why you couldn't do the same trail with your Compass. Only possible issue is with the climbs, so a second vehicle that could pull you up if your tires lose traction would be recommended if you try any steep climbs. And a spotter is a very good idea for tight spots or when you can't see the trail yourself at all. But once you have those, go for it!
Tony1911 is offline
post #7 of 7 Old 04-18-2010, 12:22 PM
VanRoadie
2007 MK Compass
Yeah, there is a little 4X4 park near my house, and I was surprised with what my little compass could do. I had a couple issues with lost traction on some very steep sections. I think I could have done it with a tiny bit more run up speed, but my wife was freaking out about the angle so we had to go back down. All in all I've been impressed with that little car though, It's more capable offroad than I'd anticipated.
VanRoadie is offline
off road , patriot , pictures
Off road = FDII, right? diver110 Jeep Compass & Patriot Forum 5 12-16-2009 04:41 PM
Safari bar on Patriot BeaterPatriot Jeep Compass & Patriot Forum 10 06-04-2008 02:35 PM
Road Noise parajeep Jeep Compass & Patriot Forum 5 04-25-2008 01:22 AM
First Off-Road Experience! mdls4 Jeep Compass & Patriot Forum 4 01-05-2008 05:59 PM
Off-road pics offroader156 Jeep Compass & Patriot Forum 5 09-25-2007 05:38 PM
