No bus???? - JeepForum.com
post #1 of 12 Old 05-15-2008, 05:02 PM Thread Starter
gerty920
2007 MK Compass
No bus????
A few days ago the "check engine light" came on as I started my Compass to head home after work. on my arrival back home I went through the user's manual and this indicated the "check engine light" no major problem unless it was flashing. The user manual states further that if the light does not go out after a few driving cycles to then have the vehicle seen to.
The light went off yesterday so I assumed no big problems. Yeah right.
This afternoon the wife went to fetch our daughter at school. When she tried to start the Compass nothing happened and a "no bus" message appeared on trip/odometer. Nothing worked, not even the emergency indicators or the windows.
I contacted Jeep and they arranged to have the towed but shortly after I arrived to wait for the tow truck the emergency indicators started flashing and the "no bus" message disappeared but the "check engine light" is back.
I know most modern cars use CAN bus to send message and signals around the vehicle so I assume that the "no bus" indicates a problem with the CAN communications system.
I will have the vehicle at the dealer tomorrow as had an appointment to have the "check engine light" seen to.
My question is after this long story, has anybody had this problem before? Was it major time and money to have fixed? The Compass has 18000km on the clock and is not even a year old? Should I be worried?
gerty920 is offline
post #2 of 12 Old 05-15-2008, 05:22 PM
Shirai_Ryu
"no bus" usually indicates a loss of communication between the various modules (computers) on the car. Im not to saavy with the metric stystem, but I do believe that 18,000km puts you well within the Warranty terms, so whatever it is should be covered.
My guess would be the T.I.P.M (Totally Integrated Power Module), but the dealership will need to do some diagnostics to determine the failure.
Shirai_Ryu is offline
post #3 of 12 Old 05-15-2008, 05:39 PM Thread Starter
gerty920
2007 MK Compass
thanks for the info shirai.
something interesting about all of this, the first time the "check engine light appeared the Compass had been standing outside in the sun the whole day and it had been the warmest day of the season so far.
Today was again a pretty warm day and again the problem surfaced. maybe the temperature has something to do with it.....?
gerty920 is offline
post #4 of 12 Old 05-15-2008, 06:42 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Yes, just a bit over 11000 miles, the warranty will cover it. I did have my engine light come on at about the same mileage as you. Checked the gas cap several times, looked everything over really well, couldn't find anything so I took it to the dealer. They wanted to replace the intake manifold saying that maybe the bracket that held the throttle cable on was broken. They ordered in the intake, I drove my Compass home and took a look at it and there wasn't any sign of anything broken. I filled up the next day and the light went out and never came back on. I think that it may have been bad fuel, possibly water in the tank. I called the dealer back and told them that I wasn't going to need the work done. Your dealer should be able to read the codes.
It may be related to this TSB:
Intermittent Op. Of Elec. Components Due To Ignition IOD Fuse Not Seated
or
No Engine Crank Or No Engine Start Due To Elect. Lockup Of WCM / SKREEM
I had a friend at a car show that had is hood up and the sun beating down on his electronic control module caused a no start condition but with the hood closed on yours it shouldn't be that kind of problem. Also the under hood temps get pretty high just under normal driving conditions.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 12 Old 05-23-2008, 07:55 AM Thread Starter
gerty920
2007 MK Compass
Some feedback on my problem. took the Compass in last week and the dealer did some diagnostics. Of course the problem could not be duplicated, Seems the "check engine" light was due to a problem with the TIPM. Dealer ordered a new one and was installed today under warranty.
Hopefully that was the only problem, let's see what happens!
gerty920 is offline
post #6 of 12 Old 05-23-2008, 08:22 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Thanks for the feedback! The wife's '03 Grand Check Engine light just came on 2 days ago. I pulled up a P0456 code so I'm trying to track down an Evaporate Emissions leak. It may be covered under her extended warranty.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #7 of 12 Old 05-23-2008, 10:46 AM
jbjeepguy
2007 MK Compass
Originally Posted by Gramps View Post
.. so I'm trying to track down an Evaporate Emissions leak. It may be covered under her extended warranty.
Or the Federal Emissions warranty.
I bike therefore I work.
07 Compass, FDI, CVT
jbjeepguy is offline
post #8 of 12 Old 10-05-2008, 09:28 AM
VTEK1
no bus on my 99 XJ (cherokee) mine won't shift outta 1st gear unless I manually shift it and I don't have a tach or speedo at the moment. good luck I think I'm going to send mine to dealership and finally give up. I've been working on it for a month.
VTEK1 is offline
post #9 of 12 Old 10-13-2008, 12:01 AM
patrick3319
2008 MK Compass
tonight I filled up with gas...started the car...EVERY light on my dash was lit up, lights were on even tho I hadn't turned them to be on (have hids and fogs)....so shouldn't be on till I turn it...than I drove a bit shut it off and tried to restart...NOTHING...called some friends, (since I had no tools) undid the battery for 5-10 mins and put it back on everything was fine...had check engine light of course...and now its gone, so no way to figure out wtf happened!....:S....OI!
patrick3319 is offline
post #10 of 12 Old 10-13-2009, 03:40 PM
Mistyfate
So my Compass just seemed to up and die on me the other day. I took it to the dealer and they said it is the TIPM and that I need a new one.
Is this a normal thing to "go" on cars? I feel like even though I've had the car since 07 that I've had a bunch of issues with it. The computer has been flashed on more than one occasion, the car has experienced some weird electrical bugs--the computer seemed to be shifting imporperly, various lights lit up on the dash, to the check engine light coming on.
This is the first BIG issue since my car has been out from under warrantee. I'm starting to wonder if it is even worth it at this point.
Has anyone else had issues with the TIPM?
Mistyfate is offline
post #11 of 12 Old 01-26-2013, 12:27 PM
Zero16hurley
No bus...
My 2012 patriot reads no bus. 10k miles. I had a horrible grinding/rattling of metal noise coming from the steering column at highway speeds only. Could not recreate the noise at the shop. Pretty much was told to deal with it. I readjusted the steering wheel and the noise stopped. The next day my wipers and turn signals turned on by themselves and would stick randomly. A month later my vehicle won't start and read no bus. Since it's under a year I have 24hr assistance. It's at the dealership. Hopefully they can give me an answer. I've had nothing but problems. Struts and mounting were replaced at 1,800 miles. Shocks are next. Driver side door doesn't fully close and rattles. If this many things can go wrong in the first 10kmiles I can only imagine what I will be be forced to deal with in the future.
Zero16hurley is offline
post #12 of 12 Old 01-27-2013, 08:58 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Those are quite a few early problems. I hope the dealer takes care of them!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
